Exxos's B-roll blog of nothing in particular
Re: Exxos's B-roll blog of nothing in particular
Anyone any suggestions to fixing it to the wall ?
My only "simple" way is to a drill a hole in the battery door, then just have a screw in the wall to hang the thing off.
There are U-shaped metal things for routers, but seem a bit weird and mostly glued on !!.
mrbombermillzy
Post by mrbombermillzy »
My missrs loves those 3M command strips:
https://www.amazon.co.uk/Command-17203- ... B000OF6X48
Just make sure you use the right ones (or amount) for the weight of the device and make sure the wall is flat and clean.
Well that cleared that up then. Not.
Literally no point in searching for anything anymore. It's just not worth the effort.
hmm...
My legs and bottom are going numb :(
Post by JezC »
I know that feeling @exxos - but I often have the other one on my chest....
:roll:
Molly is taking selfies now it seems...
ONT and phone now on its own little battery backup.. what a faff..
Took ages for the connectors and cable to come. The connector didn't fit the phone, was to short ! Seems the base unit DC jack is sunk to far into the plastic (bad design!) then they had to use a longer DC plug to fit.. Which doesn't exist to buy. So just cut the jack off the original PSU and used that.
Went to RS to check prices of some stuff and just got this..
I followed the link for the error and got..
:sigh:
I get the impression Molly wants something...
