rev6 maximum speed?
Tiggythecat
rev6 maximum speed?
Hello people, I have switched the CPU from a non FPU variant to a rev6 060 on my tf360 and are finding 66mhz and 100mhz lock the system up... is this expected behaviour? not an issue as its still plenty fast enough with the FPU. I also I have a freeway clockport device is there anyway of making it work with the NOTPORT? i tried using the same install files that work on my 1200 but it didnt do anything.
- Admin sponsor
Re: rev6 maximum speed?
Try 94mhz. 66mhz is sulky at the best of times. The only supported devices on the NOTPORT are the Solas (Because @Daedalus lives round the corner and it would be embarrasing not to support it) and the bog standard clockports.Tiggythecat wrote: 10 Jul 2026 14:27 Hello people, I have switched the CPU from a non FPU variant to a rev6 060 on my tf360 and are finding 66mhz and 100mhz lock the system up... is this expected behaviour? not an issue as its still plenty fast enough with the FPU. I also I have a freeway clockport device is there anyway of making it work with the NOTPORT? i tried using the same install files that work on my 1200 but it didnt do anything.
Users browsing this forum: Baidu [Spider], ClaudeBot and 1 guest
