First up is the Hyperboard 2:
The Hyperboard is a modern take on the Netronics ELF II Giant Board which includes additional RAM and EEPROM, input/output ports and serial connections with 32KB RAM / 32KB EPROM, CD1852 Byte-Wide Input/Output Ports, CD1854 UART, Cassette IN/OUT with proto area. The board was slightly revised in 2026 to add the ability to reserve/allocate address space on the address bus for use with add-on boards that have their own boot loading software on board, like the Netronics BASIC/MATH/ROM board.
Then we have STG ELF 2K Disk for ELF II Card:
Uses Spare Time Gizmos ELF 2K Firmware to add a Compact Flash Card "Hard Disk" to use with the ELF/OS Disk Operating System. Provides 32KB RAM / 32KB EPROM, 16C450 UART, Serial Communications with FTDI connections, USB FT232RL device, IDE connection, CF Card socket and Real Time Clock chip.
The Elf II SD card:
With 128K RAM, 32K EEPROM, TTL and Serial terminal connections and an SD Card for storage, the ELF II SD Card board provides the electronics and software to turn your AVI ELF II into a powerful RCA VIP compatible machine that is capable of reading, loading and running your software library of VIP and Chip8 programs just like the original RCA VIP.
Note: For full VIP compatibility, the VIP Keyboard for ELF II is required. Because of this it's my least favourite option, however the keyboard isn't 100% required, though it may also be necessary for using Basic, so if I need it I'll build it.
Last but by no means least is the AVI Reproduction Full BASIC Math/ROM Card.
The AVI Full BASIC Math/ROM Card is reproduction of the board that was made available for the Netronics ELF II.
I will say that personally I would prefer either the Hyperboard II or the STG ELF 2K Disk, but I will put it to the vote and abide by the results!!!
Let me know what you want to see
Please note that you won't be able to change your vote later (Just like a real election) so think carefully about what you vote for.
I will run the poll until the end of May, that way I can get the PCBs ordered when I get back from my holidays at the end of the month
