Ok, so just 4 axial caps are still missing but I should receive them next week.
And a lot of used solder braid to throw away after my de-soldering session:
8-)
Archie A3000 inbound
Re: Archie A3000 inbound
Better get an order in :)HigashiJun wrote: 23 May 2026 10:05
8-)
Definitely !
All soldering finished !
Smoke test tomorrow if time allows.
Quite the soldering project, good stuff, let us all know how the smoke test goes :)HigashiJun wrote: 28 May 2026 08:55 All soldering finished !
Yup, and I will be really fed up with (de-)soldering for quite a while now...rubber_jonnie wrote: 28 May 2026 09:05 Quite the soldering project, good stuff, let us all know how the smoke test goes :)
I will let you know for the smoke test for sure.
Yeah, the de-soldering is a huge project all on it's own!HigashiJun wrote: 28 May 2026 10:08Yup, and I will be really fed up with (de-)soldering for quite a while now...rubber_jonnie wrote: 28 May 2026 09:05 Quite the soldering project, good stuff, let us all know how the smoke test goes :)
Yay! I'm sure that the magic will stay in the chips... Though probably best remove the expensive ones first before first power on.
:crossed1:
Definitely good advice. I usually start with only passives installed and slowly build up to adding the more expensive IC's.stephen_usher wrote: 28 May 2026 20:13 Though probably best remove the expensive ones first before first power on.
Users browsing this forum: ClaudeBot, Perplexity [Bot] and 18 guests
