Indeed.
I suspect it is interfering directly with the speaker TBH as it runs directly under it, though even trying with additional shielding made no difference, just the re-route to make it fine.
Indeed.
And out of curiosity, what kind of insulation did you try ?
First I tried metalised cardboard folded over the cable with a clip onto ground, then aluminium tape similarly grounded.
I guess that should do the trick.rubber_jonnie wrote: 07 Apr 2026 22:29 ...though I may revisit and put grounded aluminium tape under the speaker for a bit of extra shielding.
Every little helps 😁HigashiJun wrote: 08 Apr 2026 00:25I guess that should do the trick.rubber_jonnie wrote: 07 Apr 2026 22:29 ...though I may revisit and put grounded aluminium tape under the speaker for a bit of extra shielding.
Users browsing this forum: apple [bot], ClaudeBot, Google [Bot], kodak80 and 13 guests
