Oooh, I think that needs to go on my shopping listIcky wrote: Tue Mar 31, 2026 8:22 pm Also I know you have a Evercade-VS as well have you seen these - https://funstock.co.uk/products/evercad ... controller
Stuff and Things.
Re: Stuff and Things.
Oops I may have pre-orderedrubber_jonnie wrote: Tue Mar 31, 2026 8:59 pmAs it goes I hadn't, wish I'd known that was coming out 6 months ago!!!Icky wrote: Tue Mar 31, 2026 8:13 pm
Oooh, must have a look at that.
Have you seen the new Evercade Nexus - https://evercade.co.uk/evercade-nexus/
Oops indeedIcky wrote: Wed Apr 01, 2026 5:21 pmOops I may have pre-orderedrubber_jonnie wrote: Tue Mar 31, 2026 8:59 pm
So I added volume control on my BBC B by adding a 10K pot to replace the on on the mainboard, but with an external control for adjusting the volume:
Now the Beeb sound was noisy before but now it's off the charts noisy, so I need to find a way to clean it up...
OK, so I had a look at the noise problem on this BBC and the results were interesting.
It's well known earlier issues could have a noise problem as the audio input pin on the 1Mhz bus picking up noise from the other buses on the machine, however mine being an issue 7 should have the fix for this built in.
So I did some digging and it seems that C18 & C21 on the -5v power supply used by the sound IC can also cause noise issues when old, so I replaced those and it did improve a little.
I was surprised by the main cause of the noise though, and found it accidentally by moving things around. I have an external ROM socket installed:
And the ribbon cable runs under the keyboard PCB over to one of the ROM sockets.
If the cable is here:
When the keyboard is installed the noise is off the charts
Re-routing the cable like this:
Eliminated 90% of the noise.
Now I was assuming that perhaps the wires to the volume pot were picking up noise from the cable that was laying on top of it, however the noise was only present with the keyboard in place.
Interesting little problem, now thankfully resolved to my satisfaction.
Well, the ribbon cable is just a big aerial.
- HigashiJun
You can also insulate the cable and route it like you did previously.
I tried that and it didn't work...HigashiJun wrote: Tue Apr 07, 2026 10:13 am You can also insulate the cable and route it like you did previously.
Quite...
