Terriblefire Accelerators
8 Bit Dreams
Moderator Team
Moderator Team
Re: Terriblefire Accelerators
Post by 8 Bit Dreams »
Wow! Not cheap..
Yeah...4-Layers, big CPLD, also RAM isn't expensive..
I need to figure out how donate works, have tried on last stream, but got message it isn't working in my country... :?
No donations required. It was just for reference.
Customs fees were 23 quid for example. This is why I try and use what I already have lying around for parts
SukkoPera
Post by SukkoPera »
HI Stephen, glad to meet you again here :).
terriblefire wrote: Sat Nov 17, 2018 11:20 pm
alenppc wrote: Sat Nov 17, 2018 9:15 pm Ok just realized the latest TF530 firmware doesn't work properly at 25 mhz, no issues whatsoever at 33 Mhz and up however.
OK. New beta available. give it a whirl.
https://github.com/terriblefire/terribl ... 7_beta.zip
Can I ask you a little favor? Can you please put 0/1 (JTAG chain ID) in the JED file name so that I don't even to look up in the docs every time to find out what file goes on which chip? :)
Anyway, in the end I didn't buy the programmer, I macgyver'ed my own with xc3sprog and a STM32 Black Pill. That makes up a very cheap programmer, cheaper than a RasPi. If anybody is interested I can clean it up and release it.
Can’t you just create flashramcpld.sh and flashbuscpld.sh scripts?
I don’t know how to do what you ask automatically and I create the jed files with a make file that auto packages everything. Hand editing 7 jeds per release (and counting) isn’t going to happen.
SukkoPera
Post by SukkoPera »
OK, no worries then :mrgreen:.
DHL just emailed to say they’re delivering today. First look at the boards tonight
SukkoPera
Post by SukkoPera »
I have a few questions:
Since the CF/IDE adapter I use supports powering through pin 20 of the IDE connector, and since it is unconnected on the TF530, is it OK if i solder a wire from some 5V pin to pin 20?
Would you also keep this in mind for your newer boards? Maybe connect it through a jumper so that it can be disabled.
Question #2: Can I connect an IDE activity LED somehow? Another thing to consider for future boards.
Question #3: What is the BYPASS jumper for?
SukkoPera wrote: Tue Nov 27, 2018 10:52 pm I have a few questions:
All my new boards are 44pin ide with power supplied.
I always just use CF adaptors with LED connectors.
Its for programming the bus CPLD without the RAM CPLD soldered in..
SukkoPera
Post by SukkoPera »
Oh ok, but so do you see anything wrong if I solder a wire to pin 20 on the 530?
SukkoPera wrote: Tue Nov 27, 2018 11:30 pm Oh ok, but so do you see anything wrong if I solder a wire to pin 20 on the 530?
That would be fine.. but its probably less messy to power it from the PWR header directly
