ATW800/2 in a MonSTErbo powered STE
Post by HigashiJun »
I've been working on this project for a while now, but my busy schedule isn't making things easy.
Since I have an STE with a MonSTErbo fitted inside and the board has a "MonSTEr bus", I wanted to make use of it somehow.
I had to mod the ATW800/2 a bit in order to fit it in my machine, so I removed the USB port and shortened the DIN connector (it goes without saying that I tested the ATW800 in the STE before modifying it !).
It now fits perfectly, but I need to cut the case to have access to the HDMI connector or try to relocate it with a HDMI flex cable...
Re: ATW800/2 in a MonSTErbo powered STE
Wow very cool project! Looking forward to seeing the results.
Thanks.
2 or 3 things to sort out and it should be good.
8-)
Cyprian
Post by Cyprian »
nice.
I need Monstebo for my short ST :)
http://260ste.atari.org
Darklord
Post by Darklord »
I need/want/must have it for my ATW800/2 equipped Mega STe! ;)
For short STs, the ThunderStorm Team has a new gimmick:
https://www.newtosworld.de/viewtopic.ph ... b708c0c7d6
Darklord
Post by Darklord »
The TwiSTer is mentioned - is that even available?
I'm not sure I've seen any posts from anyone using
one.
Thanks much.
Darklord wrote: 22 Mar 2026 06:07 The TwiSTer is mentioned - is that even available?
one.
Thanks much.
Have a look here:
viewtopic.php?t=6268&hilit=twister
Ok, so a flex HDMI cable won't be possible as there is no clearance between the HDMI connector and the STE case.
Hate that, but I have to mod my case...
Darklord
Post by Darklord »
HigashiJun wrote: 22 Mar 2026 07:20
Have a look here:
Doh. Forgot about you having one - slipped my mind.
I know I'm probably just overlooking it, but when I followed that one link it had all of
their products listed but I didn't see the TwiSTer actually on that page.
Good luck with this project - it looks like it's coming along nicely. :)
Users browsing this forum: ClaudeBot and 111 guests
