Converting HISOFT to 68K ASM "almost" works
Re: Converting HISOFT to 68K ASM "almost" works
Theres another routine in the mix..
forcing DM=1 (binary mode) here
DATA% = BITSET%(2,DATA%) ' SET BINARY MODE
so as it reads back as 1 that must be correct.
I forgot its a multiplexed bus which is confusing things as well :roll:
mrbombermillzy
Post by mrbombermillzy »
Ok, yes, guessing at the HS BASIC language constructs, that looks to be correct.
Can you find any references to register offset $09h?
(Probably called something else in BASIC or the assembly, but both must set the name with a reference to memory location Base address of RTC registers + $09h.)
mrbombermillzy wrote: Mon Feb 09, 2026 7:40 pm Can you find any references to register offset $09h?
The INIT routine has
'SET YEAR TO 20
POKEW (RTC_ADDRESS&),&B1111111100001001    ' SET ADDRESS 09H
POKEW (RTC_DATA_ADDRESS&),&B1111111100010100
After that it takes the value the user sets in the clock setter program.
It reads and writes fine there, it shows all correct time and date.
The assembly program reads the correct value, but seems to somehow end up with 28 for the year in control panel.
mrbombermillzy
Ok, lets roll back to a good place to start. How about changing this:
* Year (reg 9)
	move.w	#$FF09,(RTC_ADDR)
	move.w	(RTC_DATA),d0
	sub.w	#$FF00,d0
	move.w	d0,d7		; save YR in d7
to this:
* Year (reg 9)
	clr.l	d0
	move.w	(RTC_DATA),d0  ; save YR in d0
In your 2nd code example just before my first reply on page 1.
As Im not sure what format GEM expects the answer, you might also have to try:
* Year (reg 9)
	clr.l	d0
	andi.w	#$00FF,d0	; cut top byte values
* Year (reg 9)
	clr.l	d0
	andi.w	#$FF00,d0	; cut bottom byte values
Ive added some extra 'failsafe' instructions (namely possibly clearing any garbage data in d0) to the above routines just in case thats the bug.
Its this code which is the "best" one
https://www.exxosforum.co.uk/forum/view ... 98#p139538
I tried it again, and the year gets output as 26, but now CP is set to 42 as the year... :stars:
With your changes..
debug year shows 0, year in CP still shows 42 .
My brain hurts..
mrbombermillzy
Ok, it seems there is some sort of data transform/adjustment either somewhere else, or in the GEM end. Let me have a look...
mrbombermillzy
Ok, apparently the year is stored in the high byte.
So try changing the 2nd attempt code again with:
* Year (reg 9)
	clr.l	d0
Im not sure you tried this, as I was editing my post with failsafe test values when you answered. (Read the post 3 places up; I think this is the option you need).
mrbombermillzy wrote: Mon Feb 09, 2026 8:21 pm Ok, apparently the year is stored in the high byte.
* Year (reg 9)
	clr.l	d0
Didn't see that one no.. but the year just comes back as zero ago..
The read of the year seems fine, its writing it to GEMDOS which seems where things go nuts.
mrbombermillzy
exxos wrote: Mon Feb 09, 2026 8:31 pm The read of the year seems fine, its writing it to GEMDOS which seems where things go nuts.
Looks like its using GEMDOS function $09 PRINT LINE which converts numerical data into character data.
Im sure the routine that does the conversion needs further study then... :coffee:
mrbombermillzy
This then is that part of the code:
* PRINT_NUM: prints 0-99 as decimal string + CRLF (no leading zero)
PRINT_NUM:
	movem.l	d1/a1,-(sp)
	lea	BUFFER(PC),a1
	cmpi.w	#10,d0
	bcs.s	.one
	clr.l	d1		; clear high word for clean dividend
	move.w	d0,d1
	divu.w	#10,d1
	swap	d1		; remainder in low
	addi.b	#'0',d1
	move.b	d1,1(a1)	; units
	swap	d1		; quotient in low
	addi.b	#'0',d1
	move.b	d1,(a1)		; tens
	moveq	#2,d1
	bra.s	.out
.one:
	addi.b	#'0',d0
	move.b	d0,(a1)
	moveq	#1,d1
.out:
	clr.b	(a1,d1.w)
	pea	(a1)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	pea	CRLF(PC)
	move.w	#9,-(sp)
	trap	#1
	addq.l	#6,sp
	movem.l	(sp)+,d1/a1
	rts
Im going to have to bail out in a minute (sorry), but I will see if I can quickly find anything obvious.
