I think one without the slots is worth a try too. Maeke's turned out ok.
I will modify the original one to be non-chamfered and with no slots for options.
Floppy Support
Re: Floppy Support
Re: Floppy Support
rubber_jonnie wrote: 16 Nov 2018 12:08 I think one without the slots is worth a try too. Maeke's turned out ok.
Maeke printed 3 out at once by the looks of it.. so I will try that later as well.. likely end up better as discussed last night...
Re: Floppy Support
Will see how it turns out on my printer over the weekend too. Probably print a few sets if ok as all mine have broken over the years.
Re: Floppy Support
Cool.exxos wrote: 16 Nov 2018 12:35rubber_jonnie wrote: 16 Nov 2018 12:08 I think one without the slots is worth a try too. Maeke's turned out ok.
Re: Floppy Support
I'm definitely interested in the results.Forgottenmyname wrote: 16 Nov 2018 12:48 Will see how it turns out on my printer over the weekend too. Probably print a few sets if ok as all mine have broken over the years.
Re: Floppy Support
I printed 4 thinking it would print the top layer better as it would have more time to cool... But I ended stringy mess :-\
I was actually printing at 0.12mm heights, so I changed it to 0.2mm and increase the filament the traction a little bit more.. And these printed out almost perfectly...
The overall finish is not as smooth on this setting, but print time is significantly reduced.. And these print out perfectly fine for usage anyway.
Re: Floppy Support
Excellent! Next question, do they fit the mainboard ok?
Re: Floppy Support
Basically yes, but due to the sloping ends they are a loose fit now than before.
Re: Floppy Support
Will let you know in about an hour then, am printing 4 in black PLA+rubber_jonnie wrote: 16 Nov 2018 13:07I'm definitely interested in the results.Forgottenmyname wrote: 16 Nov 2018 12:48 Will see how it turns out on my printer over the weekend too. Probably print a few sets if ok as all mine have broken over the years.
Re: Floppy Support
Great thanks. Hopefully get my bed finally leveled just right on Sunday, then will print off one of each myself.
I have no worries that they won't 'work' as dimensionally they are correct, it's more a concern how they will print on the myriad 3D printers out there.
Will also add some over the weekend with no chamfer for those who'd prefer. Fusion 360 has an awesome history per model, so I just need to load them all up, save as a new model, then remove the chamfer. Hey presto 4 new supports with no chamfer :)
