In my particular case it was better:
HDDRIVER: 6760 kb/sec
EmuTOS: 5540 kb/sec
EmuTOS: 5540 kb/sec
Test ... how? :P What hardware is on the other end??? :Dagranlund wrote: 26 Jan 2026 18:13 For no practical reason whatsoever, but having fun needs no other reason :)
(It's just a test application now but may turn into a real floppy disk driver for TOS)
Yep, for fun is the best reason! I'm not sure there's _that_ much practical reasons to use a slow floppy drive but it's fun getting it working :)Mikerochip wrote: 27 Jan 2026 21:25 Test ... how? :P What hardware is on the other end??? :D
Yes! For fun, is the best reason! Speaking of, I need to get back to mine :P
We are going to need more ISA slots... :Dagranlund wrote: 27 Jan 2026 23:11Yep, for fun is the best reason! I'm not sure there's _that_ much practical reasons to use a slow floppy drive but it's fun getting it working :)Mikerochip wrote: 27 Jan 2026 21:25 Test ... how? :P What hardware is on the other end??? :D
I'm only at the stage of building the lower level code that interacts with the floppy controller at the moment, and testing these bits in isolation as I go.
The step after would be to hook up the higher level TOS interface and turning it into a proper driver TSR.
I've been using this card to test:
https://github.com/skiselev/isa-fdc
In _theory_ the driver should work with just about any ISA card with a floppy controller as they're all supposed to be register-level compatible.
And just because I said that I couldn't resist swapping in a different one for a quick test, and yep it works with an old HM83740 Multi-IO card too :)
(my card was similar but not exactly the same as this picture I stole off the internet)
What a coincedence I’m currently soldering that serial floppy card for my dx2. Ofcourse has nothing to do with Raven although in some way it has some things in common.. Probably Raven is the reason I got the mainboard from the big box of old electronics in the attic and started to put some cards in.agranlund wrote: 27 Jan 2026 23:11Yep, for fun is the best reason! I'm not sure there's _that_ much practical reasons to use a slow floppy drive but it's fun getting it working :)Mikerochip wrote: 27 Jan 2026 21:25 Test ... how? :P What hardware is on the other end??? :D
Haha I agree, this is the constant problem!
Nice! Dumb as I was I threw away a bunch of PC stuff many years ago cleaning the attic.Oldskool wrote: 28 Jan 2026 09:43 What a coincedence I’m currently soldering that serial floppy card for my dx2. Ofcourse has nothing to do with Raven although in some way it has some things in common.. Probably Raven is the reason I got the mainboard from the big box of old electronics in the attic and started to put some cards in.
as far as I know the design of this FDC/Serial-Card from Sergey Kisilev is open, right?agranlund wrote: 28 Jan 2026 12:51Haha I agree, this is the constant problem!
The fear of wearing out the ISA sockets, or even the edge connectors on some of my cards, is very real :D
The thing I regret the most was chucking my first 486.. a nice little Compaq all-in-one.
Wish I had more space in my small hobby room, would love to have a dx2 again.
I like it!LarryL wrote: 28 Jan 2026 13:08 as far as I know the design of this FDC/Serial-Card from Sergey Kisilev is open, right?
Maybe the FDC part could be integrated into the new "IDE/CF/Network-Card", you have in the works...
just thinking/hoping ;-)
sounds great!agranlund wrote: 28 Jan 2026 22:56
Though if I ditch one of the CF sockets, or make the board larger, I suppose I could use whatever.
Users browsing this forum: ClaudeBot, Mikerochip and 1 guest
