SpeedyTT, black screen of death !!!! HELP
Re: SpeedyTT, black screen of death !!!! HELP
:dualthumbup: :cheer:
Post by HigashiJun »
It could have been worse...
Glad you managed to fix the issue.
8-)
zfrenchy
Re: SpeedyTT, black screen of death !!!! (SOLVED)
Post by zfrenchy »
final and summarized post:
Bad soldering joint on the IC sockets
ZuluSCSI-RP2040 is blocking the booting sequence after the RAM test when the SpeedyTT is in 48Mhz mode.
zfrenchy wrote: 18 Jan 2026 01:56 final and summarized post:
:dizzy:
I'm afraid I don't understand you...
So does your Speedy work fine after all your fixes ?
What other expansions have you fitted in your TT ?
Do everything just work as it should without your SCSI interface ?
zfrenchy
Post by zfrenchy »
Yes, everything work without the ZuluSCSI installed
And don't you have an IDE drive (provided you got a Thunder IDE from the ThunderStorm team) ?
zfrenchy
Post by zfrenchy »
Yes I have it, not installed yet.
Then fit it and check if IDE works.
FYI that's most likely a software issue (zulu not working) I have TT, Speedy, both my IDE and SCSI work fine (I use a Bluescsi)
Steve wrote: 18 Jan 2026 12:38 I have TT, Speedy, both my IDE and SCSI work fine (I use a Bluescsi)
Same here.
