Stuff and Things.
Re: Stuff and Things.
Got mine set up and thought I'd got some rooms too, will have to sort through them and see if I can get any to work. Otherwise the config is set and it displays, just says synth unavailable just now.
PhilC wrote: 15 Jan 2026 14:39 Got mine set up and thought I'd got some rooms too, will have to sort through them and see if I can get any to work. Otherwise the config is set and it displays, just says synth unavailable just now.
Try this, mine came from here.
Mine is now 100% tested :)
I hooked it up to Notator on one of my Mega ST's:
And you can see the channel bars doing their thang:
I did make a config boo boo though, I had output set as pwm but it should have been set to i2s as it was the DAC output I was using and not the headphone jack. I've updated the config on my earlier post to reflect that.
Both MT-32 and Soundfont mode worked just fine.
Need to go and get some of the midi enable games and test them out :)
@rubber_jonnie thanks, have downloaded and will give them a try.
PhilC wrote: 15 Jan 2026 16:34 @rubber_jonnie thanks, have downloaded and will give them a try.
Follow the exact instructions on GitHub and you'll be fine.
FYI having run mine for a while (The Pi MT-32) the Pi get's pretty warm so I'm going to slap some heatsinks on the Pi, you may need to do the same.
rubber_jonnie wrote: 16 Jan 2026 09:37
:thumbup:
PhilC wrote: 16 Jan 2026 09:43
:thumbup:
Heatsinks fitted and under test.
Just thought I'd get a nice panoramic view of everything running this morning :)
Makes me smile :)
rubber_jonnie wrote: 05 Feb 2026 10:37 Just thought I'd get a nice panoramic view of everything running this morning :)
:thumbup:
That's way too tidy though..
I can just about see the Phoenix mug as well ;)
exxos wrote: 05 Feb 2026 10:40
:thumbup:
It's also my home office so I need to keep it reasonable. Well spotted on the mug :)
Users browsing this forum: ClaudeBot and 16 guests
