bbisi
Post by bbisi »
@agranlund
thats a very good idea
IDE with Network ? You make a egg-laying wool-milk sow :D :D :lol:
Couldn't an adapter with a USB port be made? For USB sticks and other USB devices?
Great updates as always. Been a bit busy here but booted up the Raven and it all worked first time, so I'll give it the latest updates later on this week.
bbisi wrote: 13 Jan 2026 09:21 Couldn't an adapter with a USB port be made? For USB sticks and other USB devices?
There is silicon for this. I know because we owned the company that once made them. They were used in Amiga USB host cards (Subway, Deneb, Freeway). Whether you can still source them is another matter. ST Microelectronics isp1760/isp1763 or Transdimension TDUHC124B
The problem is probably not making the hardware but the software. The USB stack and compatible class drivers are quite complicated beasts.
agranlund
Post by agranlund »
Hmmn, probably will end up something like this:
I wasn't intending for two CF sockets but I ended up with tons of unused space and realised another one will fit.
The card will have two physical interfaces for a total of four devices, where the CF cards are master devices on each interface.
Meaning if you have a CF card attached then its corresponding 40 pin header can take a slave device only.
If not, then the 40 pin header can take one master + one slave device.
That (optional) pushbutton and header is there for a convenient way to trigger NMI from outside the case.
Or perhaps reset if the case doesn't have that. Or anything.. it's just a button and a header :)
LarryL
Post by LarryL »
agranlund wrote: 18 Jan 2026 14:24 Hmmn, probably will end up something like this:
Excellent :cheer: :cheer:
Need it… :D
luciodra
Post by luciodra »
@agranlund Would it be possible to have a rom without the integrated hddrivers?
I'm having some difficulties with partitioning the SD and I don't understand if it's due to this...
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
Mikerochip
Post by Mikerochip »
Speaking of HDD Drivers.
@luciodra have you (or anyone else) seen, Uwe Seimet has released his EmuTOS HDD Driver loader!
He calls it EmuTOS_FIX :P
And it lets you load HDDriver (or other atari HD driver) that already exists on a disk.
https://www.hddriver.net/forum/viewtopic.php?t=419
So, you could use that?
I was just about to post, and ask if anyone else used it, or tried it out...
luciodra
Post by luciodra »
Mikerochip wrote: 18 Jan 2026 23:22 Speaking of HDD Drivers.
Great, I'll try it when I get back from work!
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Post by agranlund »
Mikerochip wrote: 18 Jan 2026 23:22 I was just about to post, and ask if anyone else used it, or tried it out...
I tried it out here some day ago and it appears to work from the little testing I did.
At least HDDRVUTL is reporting HDDRIVER as the active driver, and XFERRATE shows a different score so I'm assuming it's active :)
Atarian Computing
Post by Atarian Computing »
agranlund wrote: 19 Jan 2026 10:38 and XFERRATE shows a different score so I'm assuming it's active :)
Better or worse?
Users browsing this forum: ClaudeBot, jmorden, kodak80, prog99, redpixel and 4 guests
