Fixing spacebar mechanism on Falcon keyboard
The latest tweaks and fixes to keep your machine running in tip-top shape.
dml
Post by dml »
I had to do some work on a Falcon keyboard and while disassembling it, found that the plastic catch holding the spacebar carriage had cracked. When I lifted the spacebar to look, it fell off.
Of course, when I tried to detach the metal bar from the other side, the second catch also broke off :P ...that escalated quickly. It was supposed to be an electronic repair.
Now I had to figure out a good way to glue these back and decided to try welding them with acetone. Depending on the plastic, this can work better than glue (or sometimes it makes things worse).
This worked really well. Here's exactly how I did it.
- Practiced putting the piece back accurately with tweezers a few times to make sure it sits correctly and there will be no gaps or obstructions when it is back in position. In this case they both broke with a pyramid-shaped shear which made this bit easy.
- Insert the metal bar FIRST so it doesn't have to be pushed in after the broken parts are restored to their positions. It's easier to position the bar then fix the catches on top of it.
- Dip the sheared end in a cap of acetone a few times, then 'dab' it into the seat where it should be welded so acetone is wetting both faces of the weld and gets a chance to dissolve material on both faces.
- Dip it one more time in acetone then place it exactly into the seat and press it gently down to let it weld. Hold it there until the acetone gets sticky, which is a few seconds.
- if it's not perfectly straight, carefully straighten it with the tweezers but always pressing down a bit.
- Leave it well alone for a couple of hours.
Here's the first catch welded.
...and the second.
I removed the white plastic loop from the left end of the spacebar so the metal bar can be pushed into the remaining one which is still attached. This seemed to be the least awkward way to reattach the plastic keytop since the metal bar is already fitted under the plastic catches.
...then put the loose loop over the left end of the metal bar and pushed it into the spacebar, so the bar is now mounted.
Fixed!
...and then back to the original repair, which was rebuilding some corroded tracks that had disabled some of the keys. That's now also fixed and the machine is working again.
dml
Re: Fixing spacebar mechanism on Falcon keyboard
Post by dml »
Onto the next problem...
Darklord
Post by Darklord »
Nicely done. Isn't amazing how we start to do one thing with these machines
and the next thing you know, we're working on half a dozen things, going in all
directions? :)
Post by HigashiJun »
Totally agree with you @Darklord.
BTW, nice repair @dml.
Good luck with your monitor !
Darklord wrote: 11 Jan 2026 01:07 Isn't amazing how we start to do one thing with these machines
directions? :)
Seems like it's always the way.
Either that or machines just randomly fail when they were put away working...
dml
Post by dml »
I think they break out of spite when we ignore them too long :P
dml wrote: 11 Jan 2026 10:20 I think they break out of spite when we ignore them too long :P
It seems to be the way.
Darklord
Post by Darklord »
Can we infer then that our machines are female by nature? :lol:
don_apple
Post by don_apple »
rubber_jonnie wrote: 11 Jan 2026 09:51
directions? :)
On rare occasions you get lucky and the opposite happens: I just took my Macintosh Plus out of storage, which I had put away a year ago because it refused to boot the last time I checked it, to see if I can fix it.
Plugged it in, and it just booted up like nothing happened... :yay:
Great tips on the keyboard repair btw.
Return to “TWEAKS & FIXES”
Users browsing this forum: CCBot, ClaudeBot and 6 guests
