here is the results of my testing, the red X are the continuity fail (red number are the test #, not the pin #)
Anyone know where is R950 is on the board ? I cannot find it.
SpeedyTT, black screen of death !!!! HELP
zfrenchy
Re: SpeedyTT, black screen of death !!!! HELP
Ouch, that's pretty bad...
Now you have to bodge wire all the missing connections.
frank.lukas
You need a professional electric vacuum desoldering pump and experience for this kind of work. It's a multilayer circuit board and therefore quite delicate. If in doubt, clip off the IC pins and desolder them individually using tweezers.
A manual desoldering pump is completely unsuitable.
Atarian Computing
You have a later revision TT that never had the schematics published by Atari. The only schematics available are for the PGA revision so there is bound to be minor differences.
zfrenchy
I have a Hakko 470frank.lukas wrote: 08 Jan 2026 06:42 You need a professional electric vacuum desoldering pump and experience for this kind of work. It's a multilayer circuit board and therefore quite delicate. If in doubt, clip off the IC pins and desolder them individually using tweezers.
zfrenchy
Ok. ThxAtarian Computing wrote: 08 Jan 2026 06:47You have a later revision TT that never had the schematics published by Atari. The only schematics available are for the PGA revision so there is bound to be minor differences.
12-MHz
Hi zfrenchy,zfrenchy wrote: 08 Jan 2026 02:58 here is the results of my testing, the red X are the continuity fail (red number are the test #, not the pin #)
it is best to re-solder all pins of the GALs and the 74LS74.
Yes, indeed. Look at the attached picture.Anyone know where is R950 is on the board ? I cannot find it.
In some boards, R950 has a value of 33 ohms.
Best regards
Robert
zfrenchy
Can you shot to me another photo of you board top silkscreen including the region of the CPU ?12-MHz wrote: 09 Jan 2026 12:49Hi zfrenchy,zfrenchy wrote: 08 Jan 2026 02:58 here is the results of my testing, the red X are the continuity fail (red number are the test #, not the pin #)
Best regards
Robert
It will be handy to see the traces whitout the component.
zfrenchy
ALL FIXED, hoping not coming back here when I will install the SpeedyTT, Storm and LighningVME.
At the end, it was only some point to resolder, and a new budge wire between U11 pin 17 and U112 pin 2, no component damaged so far, will see after a while.
Glad you got it working again. Always a nervous time when we do work on these old systems and they stop working.
Let us know how you get on with the SpeedyTT, Storm and LightningVME.
Users browsing this forum: Baidu [Spider], ClaudeBot and 6 guests
