STFM Keyboard Remake
ReneK
Re: STFM Keyboard Remake
Post by ReneK »
Hi,
Can I get the schematics and the file for the board (PCB) or will these only be available to buy in the shop?
I would like to recreate a keyboard with the F keys and a PC layout and create a case for a raspberry computer module.
Thanks
René
tOriman
Post by tOriman »
There is no need to avoid HD6301V1P1. You can make 1:1 clone
viewtopic.php?f=27&t=6801&p=111427#p111427
tOri
https://reversing.pl/ - SSL enabled site ATARI - Power without price and necessary elementsvarious varieties for Atari and not only - useful or not, but it's worth a look ...
http://atari.myftp.org
johey
Post by johey »
Without reading through 9 pages, I'd like to ask what is the status of this project? When can I have proper keyboards for my 1040STE and Falcon 030?
tOriman wrote: 11 Jun 2024 21:41 There is no need to avoid HD6301V1P1. You can make 1:1 clone
tOri
Good to know. I’ll have a look at this and try it out. Thanks @tOriman
johey wrote: 15 Sep 2024 16:04 Without reading through 9 pages, I'd like to ask what is the status of this project? When can I have proper keyboards for my 1040STE and Falcon 030?
Unfortunately my health hasn’t been to great over this last year but am a lot better and hoping to get back into the Atari projects again soon.
Methanoid
Post by Methanoid »
Wow, a Cherry keyboard for ST would be so cool... (subscribes to thread)
johey
Post by johey »
Icky wrote: 18 Sep 2024 08:50Unfortunately my health hasn’t been to great over this last year
I am wishing you all the best!
An update at last. I have just spun the changes for the v1.1 of the Phoenix - Clickity Clack a.k.a the STFM Keyboard Remake
Revision changes from v1.0:
  • Fixed Mouse and Joystick port incorrect wiring - mouse was working in wrong port and up was left etc. Don't know how I did that
  • Moved Return key to the left by 1-2mm there was a gap on the left and it was rubbing against the key to the right
  • Whole QWERTY row moved to right by 1mm - similar to above Q was rubbing on key to right and end of row was contributing to above
  • Added 2mm perimeter around the whole board so it fits into keyboard area in case - will fit snuggly now.
  • Moved HD6301 up by 2mm - F10 was touching the HD6301
  • Changed resistors to smaller network ones where possible and where I missed some pull-ups
  • Changed Power LED switch to be correct RGB order
  • Changed FDD LED switch to be correct RGB order and also swapped to common anode with I had incorrectly used common cathode
  • Added holes for key plate fixing
Just to finish off before sending to the PCB manufacturer is:
  • Add Return key supports - they are on the original Mega Keyboard
  • Add Numeric Pad 0 key supports - they are on the original Mega Keyboard
  • Add Spacebar supports - they are on the original Mega Keyboard
  • Possibly add Control Key supports - not on the Mega Keyboard but the button is the same size as the Numeric Pad 0 and adding the cut-out for the support won't hurt if someone wants to add it
Cyprian
Post by Cyprian »
Icky wrote: 06 Jan 2026 21:07 An update at last. I have just spun the changes for the v1.1 of the Phoenix - Clickity Clack a.k.a the STFM Keyboard Remake
nice progress.
BTW does it support Mega ST CapsLock LED https://www.atari-forum.com/viewtopic.php?t=22968?
http://260ste.atari.org
Cyprian wrote: 06 Jan 2026 22:23 nice progress.
It does have that circuitry in place :)
Cyprian
Post by Cyprian »
great, thanks
Users browsing this forum: ClaudeBot, semrush [bot] and 182 guests
