Doesn't look too bad though, how does it compare to an original, and does it actually fit? More importantly, does the screw go through the middle!exxos wrote: 15 Nov 2018 10:49 Looks like the top slots half melted together at the top.. will see if I can open them up with a knife...
Floppy Support
Re: Floppy Support
Re: Floppy Support
Looks like it needs to be about 1mm taller overall.. also the slots need making twice the size..
Re: Floppy Support
Doesn't fit, but there is no "give" because of the "fused" slots most likely..rubber_jonnie wrote: 15 Nov 2018 10:51 Doesn't look too bad though, how does it compare to an original, and does it actually fit? More importantly, does the screw go through the middle!
screw... means getting up and going looking... :roll: :lol:
Re: Floppy Support
Might be ok for a long button machine, I believe they are shorter.
I can easily make another model that's taller. As for the slots, I will print one out at home to see what's what, they were very narrow on the post I used to get the dimensions, so I'll need to have one in my hands to figure it out properly. Yours look about 1mm. I can probably add a chamfer to help it go into the hole.
Not bad for a first go though. Nothing too hard to fix.
Screws are 3mm I think, and hole is 3.8, so should be fine. When I have printed one I will check.
Maeke
Re: Floppy Support
Try to print it slower, let's say 30mm/sexxos wrote: 15 Nov 2018 10:49 Looks like the top slots half melted together at the top.. will see if I can open them up with a knife...
If i take too long to reply, sorry my cat is sleeping on my laps.
Re: Floppy Support
Will do!
Re: Floppy Support
Tried screw, the whole is the right size, but because the smaller end of the thing is a little scrappy with the print, the screw will not go right the way through...
It is probably also a point that if the end is going to be squashed once inserted into the motherboard, the hole will actually be even smaller.. So it might be a idea to make the end hole where the cutout groove is, a fraction larger to give it a little bit more play room.
Re: Floppy Support
Settings I printed before was...
That is a little "fast" for delicate work I think...
So I halved it and trying again...
So print time before was 18mins, now its 28mins.
Re: Floppy Support
Will try as soon as I can :)exxos wrote: 15 Nov 2018 13:00 Tried screw, the whole is the right size, but because the smaller end of the thing is a little scrappy with the print, the screw will not go right the way through...
Re: Floppy Support
Be interested to see the results, Lee Ashmore on FB has suggested .2mm for the layer for strength.
