exxos blog - random goings on
Resoldered both headers and sockets for bits 8-15.. made no odds :roll:
Random idea.. This H5 had a IMP MMU.. So replaced that out...
Only now bloody works !!!
Put back the IMP MMU...
I've checked the pins on the IMP and swapped them again.. Same issues... So IMP MMU really doesn't like my DRAM tester board for some reason :roll:
Why is it always me who ends up with these stupid problems all the time :roll:
exxos wrote: 11 Dec 2025 20:27 Why is it always me who ends up with these stupid problems all the time :roll:
Can't drive (what I assume is) a massive additional capacitance? Or is the test board buffered, in which case is the IMP chip unhappy with the buffered timings?
Badwolf wrote: 12 Dec 2025 10:47 Can't drive (what I assume is) a massive additional capacitance? Or is the test board buffered, in which case is the IMP chip unhappy with the buffered timings?
There is no buffering on the test board..
IMP tend to be more noisy.. So I just guess that is part of the problem.. All the extra inductance and capacitance adds up to the point where the thing becomes unstable... But this doesn't happen with the Rioch MMU... But they tend to be a little more "quieter".
I suppose a theoretical fix would be to have some larger in series resistance with the RAM signals on the board.. But not really worth spending the time on it..
So my H5 B1 seems to have a "unsolvable" RAM fault :roll:
Data bus seems to all switch low and give correct ROM start.
Changed the MMU, CPU, GLUE..SIMM. Resoldered the simm socket, RAM resistors, MMU, GLUE, SHIFTER..
The Only time anything changed was when I resoldered the buffer chips.. Before it would randomly change pattern moving my hand over the motherboard. Since resoldering , its stopped doing that.
DRD5
DRD7 (a couple others look the same)
So may have to change both the chips.. which is annoying.. as I don't think I have any spares :roll:
Looks like the pattern just changed :shrug: now the screen flashing red rather than the lines :shrug:
The plot thickens because I get different results on either end of that highlighted track...
The track on the bottom of the motherboard continuity checks fine but it does not continuity check on the top of the board where the IC is soldered down...
I suspect a faulty via !
Bodge wire time..
TaaaDaaaaa ! :yay:
Who makes your PCBs? They obviously don’t do proper panel testing
stephen_usher wrote: 18 Dec 2025 18:51 Who makes your PCBs? They obviously don’t do proper panel testing
I've used about four different places so far... But that board had been working previously...
I am going to investigate who made that board though... But on later boards I started making the vias larger,
JLC made those boards.. :roll: I don't use JLC for them anymore anyway. To many issues all the time.
Now I have the floppy drive working :lol: time to test some CPUs at 16MHz for the store :)
:sigh:
Now seems to have developed into more weird faults :roll:
Users browsing this forum: ClaudeBot and 14 guests
