Floppy Support
The place to discuss & share your 3D models or printable parts!
Floppy Support
Ok, so I literally just designed these and haven't yet done a test print, so use at your own risk. Dimensions taken from a real one, so I've tried to be as accurate as possible, whilst also trying to learn some Fusion 360.
FDD_Support.stl
P.S. I will report back as soon as I have a chance to print and test.
Re: Floppy Support
Great idea! Will give it a try tomorrow!
Re: Floppy Support
exxos wrote: 15 Nov 2018 00:28 Great idea! Will give it a try tomorrow!
Cool, let me know how it goes.
Maeke
Re: Floppy Support
Post by Maeke »
I was hoping to see one soon. :thanksyellow: :thanksblue: :yay: :bravo: :goodpost: :cheers:
If i take too long to reply, sorry my cat is sleeping on my laps.
sandord
Re: Floppy Support
Post by sandord »
Nice work! Maybe you can make a second one with reduced height, since there are two different drive heights. The drives with the long eject button are a few mm higher thus need shorter posts.
I should do the same for the brass spacer replacement I made.
Re: Floppy Support
sandord wrote: 15 Nov 2018 09:51 Nice work! Maybe you can make a second one with reduced height, since there are two different drive heights. The drives with the long eject button are a few mm higher thus need shorter posts.
Would be quite easy to do, do you know the height difference at all? If not I have a long button 1040 I can pull one out of to check.
My only concern are the slots, they are very narrow (.5mm) and as I haven't had a chance to print yet, I don't know how they will turn out.
I downloaded the brass spacer replacement you made from Thingiverse, though I haven't tried to print it out yet.
sandord
Re: Floppy Support
Post by sandord »
rubber_jonnie wrote: 15 Nov 2018 10:10 Would be quite easy to do, do you know the height difference at all? If not I have a long button 1040 I can pull one out of to check.
I'm travelling today so I can't check but it was something like 4mm. Better measure the real thing to be sure though.
Re: Floppy Support
Printing now :)
:ball:
Re: Floppy Support
exxos wrote: 15 Nov 2018 10:22 Printing now :)
:ball:
Cool, can't wait!
Re: Floppy Support
Looks like the top slots half melted together at the top.. will see if I can open them up with a knife...
Return to “3D MODELS”
