Atarian Computing
Post by Atarian Computing »
luciodra wrote: 14 Nov 2025 16:01 Which version of Cubase can you run? I'd like to try it but I can't at the moment. A few months later I managed to start it, but then...
3.10 which is the latest I believe. I got it from my own repo: https://filerun.atariancomputing.com/gu ... d5d82fc6fb
agranlund
Post by agranlund »
DoG wrote: 14 Nov 2025 14:26 Wow! I looks like that page was built 1999 :shock: :D
I love it! Fits the customer base and the target computers :)
agranlund
Post by agranlund »
Atarian Computing wrote: 14 Nov 2025 16:09
I'm surprised it started :)
But yep, the MROS it comes with does Atari built-in midi by direct hardware access.
That part I think was removed, and suitable driver was added to get Cubase going on V4SA. I'm sure it can be possible to piggyback on the hard work done by Pep and make a driver using Atari Xbios or direct-ISA etc.
I'm not sure if I'm imagining or not, but I want to recall something about some EmuTOS incompatibility too but I'm not 100% there.
But as far as I understand Cubase does at least work to some degree on V4SA, which runs EmuTOS.
luciodra
Post by luciodra »
Ok, work :D
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Post by luciodra »
I purchased the HD Drivers but I can't install on Raven!!!
What am I doing wrong?
Where are you leaving from?
Ok, solved after RESETVM.PRG :shock:
ET4000AX 1Mb T0
PicoGUS 2.0
LarryL
Post by LarryL »
Hi,
What kind of wireless Keyboard/Mouse are you guys using?
I bought a cheap set from HP with a 2.4G USB Dongle
Keyboard works fine but Mouse is freaking out - jumping around the desktop.
Maybe too much DPI? can switch between 1000/1200/1600 DPI - but all three are unusable
Cheers
Michael
LarryL wrote: 22 Nov 2025 14:59 Hi,
Cheers
Michael
I've had the same issue, it probably needs a small firmware tweak to slow down mouse sampling or something like that.
Mikerochip
Post by Mikerochip »
PhilC wrote: 22 Nov 2025 16:09 I've had the same issue, it probably needs a small firmware tweak to slow down mouse sampling or something like that.
A friend of mine, borb, was looking at building a raspberry pi pico replacement for the eiffel, etc, and he found that there was a large range of DPI hard set on even the small sample size of mice that he had at home,
so, for his set up, I believe he implemented a set of sampling rates, that are user selectable.
I wonder if something similar is needed here?
I think he was looking at getting a dynamic dpi range working, by looking at the hid report dpi, but, I don't remember how far he got, or, even if he found it to be viable.
@Mikerochip Agranlund has swapped the pic normally used in the Eiffel for a Chinese stm32 copy and made the software compatible with the Eiffel app but has also added USB, bus mouse etc, so I suspect a sampling rate change or whatever is required will be quite easy to do.
LarryL
Post by LarryL »
Thanks!
Just ordered a mouse which can be configured for 400 and 800 DPI - maybe this works better
Users browsing this forum: ClaudeBot, mikro and 2 guests
