Raven060 (luciodra build).
luciodra
Re: Raven060 (luciodra build).
Ok, assembled and seems to work well. Tomorrow it's IDE's turn... :D
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Could someone take a photo of the byteswap adapter mounted on the motherboard?
Thank you !
Thank you !
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra
Ok, everything seems to work and also the Byteswap adapter finally.
Can you recommend a filesystem for Atari st? Are there only PP and HDDrivers? They have high costs and this would only be justified for guaranteed operation on Raven, while I'm only doing some tests at the moment...
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
kodak80
HDDriver has a demo available that allows testing before buying:
https://www.hddriver.net/en/demo.html
luciodra
Yes, but it really has too many limitations.kodak80 wrote: 12 Nov 2025 09:41 HDDriver has a demo available that allows testing before buying:
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
Atarian Computing
HDDriver is rock solid on the Raven. Highly recommended, used it for literally decades.luciodra wrote: 12 Nov 2025 08:43 Ok, everything seems to work and also the Byteswap adapter finally.
luciodra
Ok, then I'll consider the purchase.Atarian Computing wrote: 12 Nov 2025 10:23HDDriver is rock solid on the Raven. Highly recommended, used it for literally decades.luciodra wrote: 12 Nov 2025 08:43 Ok, everything seems to work and also the Byteswap adapter finally.
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
I'm using HDDriver here. Mine is a couple of versions old now but appears to work fine.
It should be said that for EmuTOS and MiNT you don't need any third party drivers.
For MagiC it's a must though.
And, for some theoretical future effort to get official Atari TOS running it would be too.
(I've been tempted myself but holding off such endeavours to maybe piggyback on work that may or may not be happening in the context of a different Atari-wannabe machine)
luciodra
Is it a must or is it necessary?agranlund wrote: 12 Nov 2025 19:43 I'm using HDDriver here. Mine is a couple of versions old now but appears to work fine.
I saw that there are other works (PP or the Putnik drivers that I used on SatanDisk)?
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Ah, sorry. Don't know if HDDriver in particular is a must. It's the only one I tried since I'm used to it from the ST.luciodra wrote: 12 Nov 2025 19:55 Is it a must or is it necessary?
What I meant to say is that some kind of Atari harddisk driver is necessary for running MagiC.
I haven't tried the PP driver, or some of the other alternatives.
