Stuff and Things.
Re: Stuff and Things.
Some general repairs to the Dolch LPAC-486 today after the FDD decided to fail on me. Here it is all naked like:
I've been using it with the MQP Programmer I got from @exxos and needed to get the software off for a little experiment, but sadly all the drive did was make a buzzing noise and did nothing.
It turned out that the drive was non-standard too and used a 26 pin FFC to connect to an internal adapter. Bugger I thought as I realised that even if I did bin that adapter, since it was a attached to a normal floppy cable, none of the spare FDDs I had would actually fit as the drive appears to be a laptop/server drive so half the height of a 3.5" drive leaving me with no option but to fit something similar.
Then I remembered some server FDDs I'd raided ages ago and stuffed into a drawer and one of them worked a treat!!!
So, all back together and I was able to copy off the MQP software and move it over to - my Book8088 :)
Here it is all hooked up and just having read a 27C256 as a test:
And the software runs just great especially with the Book8088 in Turbo mode:
The main reason for doing this was simply the size of the Dolch. While it's portable, it does require a lot of space, even more with the MQP 170 hooked up, so using the Book8088 means a very small footprint, plus it can be run off the battery so doesn't need an external PSU.
Very happy with the results.
Post by HigashiJun »
Hmm, a naked Dolch...
:lol:
Ooops I did it again...
Another waif and stray I fell into by accident:
It's a re-cased ZX81 that looks to have the same keyboard as the ZX81 I disposed of back in the day before I realised I was going to collect this stuff...
Also comes with a 16K RAM pack which I will likely repurpose for the ZX80 whenever I get it working...
Seems to be missing the 7805, but it could be underneath the PCB and connected to the metal case for better thermals. Also, it's an issue one :)
More on this when it arrives.
rubber_jonnie wrote: 04 Oct 2025 16:47 Another waif and stray I fell into by accident:
:lol:
The kind of accident happening to a lot of members on this forum...
HigashiJun wrote: 05 Oct 2025 03:08
:lol:
Indeed it does...
:dizzy:
Most ZX81s are Issue One boards. :-)
stephen_usher wrote: 05 Oct 2025 09:52 Most ZX81s are Issue One boards. :-)
My other one is too.
Well I'm nearly in France again 😁
We should land in another hour or so, then we've got about 3 1/2 hours in the car before we arrive, which is likely to be about 0100 on Sunday morning.
Will be about on the forum but not doing a lot other than eating drinking and being merry for my birthday 😁
rubber_jonnie wrote: 18 Oct 2025 19:54 Will be about on the forum but not doing a lot other than eating drinking and being merry for my birthday 😁
:yay2: :cheer: JOYEUX ANNIVERSAIRE ! :cheer: :yay2:
HigashiJun wrote: 19 Oct 2025 03:21
Merci beaucoup :)
Users browsing this forum: ClaudeBot, mv2112, OAI-Search [Bot] and 18 guests
