RESET circuit tweaks
Re: RESET circuit tweaks
Forgottenmyname wrote: Sat Nov 10, 2018 8:01 pm
Icky wrote: Sat Nov 10, 2018 7:59 pm
Must of seen the same thing at the same time :D
470 and original is the 10
So by my calculation thats 480uF assuming those numbers are uF.
Yes 480uf as both are in parallel.
PaulJ
Post by PaulJ »
Icky wrote: Sat Nov 10, 2018 7:58 pm
Forgottenmyname wrote: Sat Nov 10, 2018 7:51 pm If it helps, here's a photo of my Mega reset circuit, in case something is a different value to the schematic.
Thanks Forgottenmyname - I notice your C3 is two caps in parallel. What value are they?
No double cap here. Its a 10 uf
PaulJ
Post by PaulJ »
Does the second cap look factory or a user hack?
Just tried 470uF in parallel.
Its weird. Its just doesn't seem to be behaving as expected. Reset switch doesn't affect anything. Have checked and checked the circuit. I have two TL7705's so both of them cant be duff.
Just looking at the data sheet at the mo, the difference in CT will mean a longer reset delay if I am reading this correct, so just means a different delay. Maybe one of my Mega's is a little slow at starting and needed encouragement?
Icky wrote: Sat Nov 10, 2018 8:14 pm Just tried 470uF in parallel.
And now its gone back to the occasional bouncing inverted reset out after powering on again.
Being thick today but comparing schematics, mega values for C1 and C is .1uf but we are using 10nf.
Also bizarrely, the data sheet for the 7705 shows ref connected to VCC but on the mega drawing and the reset board it goes to gnd via a cap.
data sheet if useful
http://www.ti.com/lit/ds/symlink/tl7705b.pdf
Forgottenmyname wrote: Sat Nov 10, 2018 8:27 pm Being thick today but comparing schematics, mega values for C1 and C is .1uf but we are using 10nf.
Interesting spot. I just powered on the prototype circuit again and it seemed to work with pulses.
Screen Shot 2018-11-10 at 20.27.15.png (21.98 KiB) Viewed 4628 times
Icky wrote: Sat Nov 10, 2018 8:30 pm
And now its back to no activity on inverted Reset. :headbang:
