Emutos 192kb, IDE Altram question
Upgrade or replace the ROM.
BlankVector
Re: Emutos 192kb, IDE Altram question
Post by BlankVector »
Oldskool wrote: 30 Jun 2025 17:23 Yes but I’m not sure if that is fully compatible with the dstb1 altram drivers which need to be loaded as well at least I think they need to be with the version 2 firmware.
In that case, run ETOS256*.PRG from floppy, then the dstb1 altram drivers. In this order, from AUTO or Desktop. Theoretically, it should work. If you try, you will see quicly.
Subscribe to my Vretrocomputing channel on YouTube and Facebook. Latest video: Display a color pixel in assembly language on Atari ST.
Oldskool
Post by Oldskool »
Yes works..
All my issues with the dstb1 are fixed now thanks to the new ultrasatan firmware.
Really messy…..
Now I need a rom….
BlankVector
Oldskool wrote: 30 Jun 2025 19:59 Yes works..
Fine :D As you see, there are never problems with EmuTOS.
Oldskool wrote: 30 Jun 2025 19:59 Now I need a rom….
Here it is. I used the official EmuTOS 1.4 sources, with custom build.
etos192uk.zip
Built with:
make 192 UNIQUE=uk DEF="-DCONF_WITH_ALT_RAM=1 -DCONF_WITH_IDE=1 -DCONF_WITH_ULTRASATAN_CLOCK=1" -j ELF=1 TOOLCHAIN_PREFIX=m68k-atari-mintelf- LTO=1
As there is very, very little free space free with the standard compiler, the new features can't be added without removing something else. So I used the m68k-atari-mintelf compiler with GCC 13 instead. This allows to enable the LTO feature (Link Time Optimization) to save more space. So I have been able to enable Alt-RAM, IDE and UltraSatan clock into the 192 KB ROM. There are even 4.5 KB free for other features :lol:
Bonus: If you tell me what is the address range used by the dstb1 Alt-RAM, I will add support for it directly into the EmuTOS ROM, then you won't need any additional driver.
Oldskool
Post by Oldskool »
Sorry I ever doubted Emutos..
Yeah all the issues I had with the dstb 1 and emutos and crashes were Ultrasatan related it seems,
The new firmware soved it,
As the dstb1 has a very cool feature to kick a rom file to altram which never worked for me but now it does. So I can kick any tos rom file now…
So maybe can just keep the 1.04 in. Will test a bit first..
It was the Ultrsatan all along. I should have known.. Its in the name..
szeremiocki
Post by szeremiocki »
Oldskool wrote: 30 Jun 2025 22:14 Sorry I ever doubted Emutos..
Do you mean that dstb1 is now stable in 16mhz+altram? David hasn’t updated his github repo, there is still warning there about instabilities — is this new development a hope that we can now start building dstb1?
Regards,
szeremiocki
Oldskool
Post by Oldskool »
Yes it is very stable on a standard ST. I still have some issues with a blitter however this does not seem to be universal.
I would say stable on a normal ST.
szeremiocki
Is it Sstandard build or modified in your test effort?
Oldskool
Post by Oldskool »
The modified one:
viewtopic.php?t=7206
Return to “ROM UPGRADES”
