luciodra
Another doubt concerns the Samtec SWT-122-01-F-D-RA component for building the byteswap adapter, because I only find the Samtec SQT-122-01-F-D-RA: is it the same thing? Thank you. You are doing a great job!
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
I double checked my order history and indeed, the part I ordered was SQT-122-01-F-D-RA and not SWT-.
Thank you! I have corrected that typo in the readme now :)
luciodra
Can I ask you where you ordered from?
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
@luciodra , I got them from Mouser but I had enough other stuff in my "waiting to order" list to reach the point of free shipping.
luciodra
I'm trying my 5420 but there are only a couple of resolutions that I can match. Now I have a nice 640x480x4 that I couldn't use before. The other resolutions don't even fiddle with VMG but nothing...
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
@luciodra , I wonder if my code is failing to detect the GD5420 variant.
That card doesn't support linear access to the full framebuffer, but the driver is meant to support larger-than-vga resolutions by help of automatic bank switching.
Would be interesting to see what the serial logging says when you use the attached debug build (goes in c:/nova/default/auto)
luciodra
A little better but...first the screen remained black, now white and then a ghost screen.
Ah,the 640x480x4 screen no longer works. No, after a minute of black screen, a color screen opens.
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Yeah it wasn't intending to fix anything. I wast mostly, or rather only, interested in seeing what it printed to the serial output.
Are we still able to use the SMT EPROM Simms? Iight make up one if so.
agranlund
I'm using them, I have one with SST39LF802C and another with SST39LF401C.PhilC wrote: 29 Aug 2025 16:56 Are we still able to use the SMT EPROM Simms? Iight make up one if so.
Users browsing this forum: ClaudeBot and 204 guests
