LED doesn't light up
Reluctant16bitter
Post by Reluctant16bitter »
So, today I finally received my new PSU and after installing it, my newly bought STE works (I think) as it should. I could format a floppy and save the desktop config to it, and it boots from my ST4SD. I can also start games from it. There are just a few things that bother me. one of which is that the power led to the left of the keyboard doesn't light up. Does this indicate a bigger problem? And if not, can I replace it?
Atari 1040STE (4 MB RAM) | Sinclair ZX Spectrum +2A | Sony HB-F1XV MSX2+ (512 KB RAM, 7MHz Z80, WozBlaster OPL4, PowerGraph Light V9990) | Philips VG8235 MSX2 (1 MB RAM, 7MHz Z80) | Mitsubishi ML-FX1 MSX
Re: LED doesn't light up
Reluctant16bitter wrote: 19 Aug 2025 18:06 So, today I finally received my new PSU and after installing it, my newly bought STE works (I think) as it should. I could format a floppy and save the desktop config to it, and it boots from my ST4SD. I can also start games from it. There are just a few things that bother me. one of which is that the power led to the left of the keyboard doesn't light up. Does this indicate a bigger problem? And if not, can I replace it?
What I've seen happen with the power LEDs is for the LED to be pushed in and it damages the connection on the PCB as the LED is just soldered in, should be repairable as likely just a broken connection.
Reluctant16bitter
Thanks, I'll have a look then.
Reluctant16bitter wrote: 20 Aug 2025 10:04 Thanks, I'll have a look then.
Be aware that there are rubber domes under the keys (In most keyboards) and not all spots are filled with them. There are reference images here: Keyboard Reference
Reluctant16bitter
Good to know. Thanks for the heads-up!
Users browsing this forum: amazin, ClaudeBot, Qwantbot and 7 guests
