There’s no difference between the ROMs in all those systems and the language makes no difference.
Check that you have them in the right order and that the ROM image has been split correctly.
Atari 1040STFM failed on moving from 2 chip Rom into 6 chips.
Re: Atari 1040STFM failed on moving from 2 chip Rom into 6 chips.
As @stephen_usher said, the ROMS make no difference.
Going by the pictures the ROMs are in the correct sockets, so it may be an issue with the images you've burned to them.
I've attached a zip file containing:
If neither work then it is very possible there is some other issue at play.
I presume you erased those ROMs prior to programming BTW? I'm only asking because with used ICs sometimes they aren't erased, or not erased for long enough.
- ROMDUMP - A ROM imaging tool for TOS
- ROMSPLIT - A ROM splitting tool for TOS
- 6 ROM images created from TOS 1.04 English using the tools above on the HATARI emulator. They are in the ROMDUMP folder.
- Attachments
- Archive.zip.txt
- (260.67 KiB) Downloaded 37 times
Thanks for the images, I'll try later next week
and get backk if finally got it working.
Thanks everyone for help it finally worked with ROMs from rubber_johnny.
It seems that something went wrong during split of my ROM...
Finally my Atari speaks shakespeare's language
To busy bee, or not busy bee?
radzio222 wrote: Tue Jul 29, 2025 8:01 am Thanks everyone for help it finally worked with ROMs from rubber_johnny.
Finally my Atari speaks shakespeare's language![]()
