Id go for those and either crimp or solder a pcb plug / header on the end.exxos wrote: 27 Jun 2025 16:25 There are these in China.. Likely my only option other than buying the USA bracket so far.
Fixing my Milan 040 (or not) blog
Re: Fixing my Milan 040 (or not) blog
Yeah its about my only "good" option currently.PhilC wrote: 27 Jun 2025 17:53 Id go for those and either crimp or solder a pcb plug / header on the end.
Though I may not even bother with the mouse to start with, I always use the keyboard anyway :lol: I need to see if my spare USB keyboard works with PS2 yet. Otherwise I will have to order a PS2 keyboard. But at least they don't cost much anymore anyway.
I wonder if one of these cases could be hackable..
https://www.novatech.co.uk/products/ant ... 048-3.html
I was mostly looking for a case with a lot of slots on the back.. There isn't *much* size difference from a ATX from what I can tell. If the slots line up with the Milan MB, maybe some creative new mounting holes might be enough to make it all fit :hide:
I will have to go looking in the loft see what junk is up there. I'm pretty sure I have a old ATX case up there. But no idea what it is anymore.
viking272
Im guessing you would you need to put your own standoffs inside, is that an easy task?
Yes..
For someone who knows what they are doing yes... People like me, no :p
Only way I know if tac welding or just drilling holes in the side of the case. Maybe the dome top style bolts if black wouldn't look to bad.. Would look better than a discoloured 30+ years old broken case anyway..
EDIT
Saying at, the internal metal isn't visible so drilling holes would likely be fine...
mrbombermillzy
Ahem...
https://www.ebay.com/itm/286619570634?_ ... R9Tf57n2ZQ
Strange... it doesnt appear on a UK search (although its advertised in Ebay USA but actually based in the UK :lol: )
He may even post if asked nicely, or someone around Brighton area can pick it up for you. :)
It was already mentioned... viewtopic.php?p=130351&hilit=Ebay#p130351
It could be a option if the guy would post it..
mrbombermillzy
Oh, I see.
Well, its got to be worth a shot asking about postage rather than paying some ludicrous 'rare' price and/or from USA postage and taxes. :)
dml
...have been bogged down in work nonsense but I sorta caught up on that L88M mask drama - had no idea that had been going on. So now 68040s are also turning unobtanium? By the time anyone bakes a new 040 card for Ataris there won't be any left :p it was a lot easier to get them before...
BTW @exxos - the 68040 has 8kb cache. Two caches - 4kb each. So yes its a big jump :)
d:m:l
@dml yeah just China allover really. The 060 CPU were the same. Once China figured out people only wanted the rev6 mask that's what they were reprinted as. I bought loads of them a few years ago for my store. The amount of returns I had to do... Cost a small fortune. In the end China reprinted all 060s... Even the genuine rev6 ones. Madness. Even more mad is the price of rev1 now.
Ultimately it's why I want to redo the ST chipset to just use a faster bus. We should be able to hit 32mhz without much issues. But that's full 32mhz bus with 32mhz writes. STram won't be a bottleneck anymore. Then later move to the 030 for full 32bit... No need for accelerators and multiple other hacks then ;) I really need to get back to all that stuff.. Just never enough hours each day for everything..
Users browsing this forum: Bing [Bot], ClaudeBot, jmorden, nicknm, sporniket, Steve and 17 guests
