Fixing my Milan 040 (or not) blog
Re: Fixing my Milan 040 (or not) blog
Currently its a very expensive beeper ! :lol: :D
Have a lot of activity on D1 now :)
Activity on D0-D2 (didn't check others) but a LOT of cycles going on now!
dml
Post by dml »
Did you make backup the flash with the TL866 before writing? (In case the other programmer was misbehaving - since it wasn't erasing properly?)
dml
Post by dml »
Beeping seems like a step forward :p presumably it can only beep if it managed a lot of other stuff first.
dml wrote: 24 Jun 2025 13:52 Did you make backup the flash with the TL866 before writing? (In case the other programmer was misbehaving - since it wasn't erasing properly?)
Nope.. Because it verified exactly as the bootblock anyway, so I didn't see any need to back it up.
dml wrote: 24 Jun 2025 13:55 Beeping seems like a step forward :p presumably it can only beep if it managed a lot of other stuff first.
Indeed :)
I suppose constant beeping is error for some idiot removed a lot of stuff from the motherboard :P
dml
Post by dml »
exxos wrote: 24 Jun 2025 13:55 Nope.. Because it verified exactly as the bootblock anyway, so I didn't see any need to back it up.
:thumbsup: was really just in case the positions/offsets of things turned out to be correct after all but that seems unlikely now, given the beeps!
Can't tell from the video but are the ICs still missing or did you put them back? Would be cool to see some POST output from the ISA bus next
dml wrote: 24 Jun 2025 13:58 Can't tell from the video but are the ICs still missing or did you put them back? Would be cool to see some POST output from the ISA bus next
The large IC is still missing, ordered from Poland so waiting for it to arrive.
I could plug a graphics card in, but I don't know if any work at this point.
Current "view".
Id try and et4000ax graphics card if you've got one @exxos as those are the default for EmuTos and others. Even if you get a synced output you know you're going the right way
PhilC wrote: 24 Jun 2025 14:16 Id try and et4000ax graphics card if you've got one @exxos as those are the default for EmuTos and others. Even if you get a synced output you know you're going the right way
Uwe said a S3 trio chipset will work.. I have one of those and 2 others of what I can find..
Users browsing this forum: Acsi, ClaudeBot, Google [Bot], prog99, sporniket, trendiction [bot] and 17 guests
