@agranlund was that using the W32i program you sent me? The blitter scores are so much quicker
agranlund
Yep the same program (and a card that is wired up to support interleaved mode. mine has 16 pieces of 45ns ram chips)PhilC wrote: 20 Jun 2025 09:57 @agranlund was that using the W32i program you sent me? The blitter scores are so much quicker
I'll integrate the interleave-enable code in the bios and add an option for it in the menu.
Ok, that definitely doesn't work for mine but I do have another W32i card on its way, already with 2mb ram, so hopefully this one will do.agranlund wrote: 20 Jun 2025 10:58Yep the same program (and a card that is wired up to support interleaved mode. mine has 16 pieces of 45ns ram chips)PhilC wrote: 20 Jun 2025 09:57 @agranlund was that using the W32i program you sent me? The blitter scores are so much quicker
BTW, this looks an interesting project
http://www.alexandrugroza.ro/microelect ... index.html
If my other W32 card works, I might try building one of these using the current one as a donor board.
agranlund
Updated the release package:
https://github.com/agranlund/raven/rele ... .A1.latest
20250620
rom: ckbd support
rom: eiffel key-repeat fix
rom: autorun srec programs after upload
firmware: (ckbd) added ckbd firmware binary
firmware: (nessi) reversed order of ram slots
rvbios: ET4000/W32i memory interleave setting
rvnova: ET4000/W32i memory interleave support
@dml , this nessi firmware should be a good match for your huge cpu heatsink :)
20250620
rom: ckbd support
dml
That's awesome - thank you!agranlund wrote: 20 Jun 2025 20:19 @dml , this nessi firmware should be a good match for your huge cpu heatsink :)
Hopefully I'll get the final bits very soon to start testing the machine properly.
d:m:l
frank.lukas
I have an ET4000W32i with 8x 256kx4 chips. Is it possible to solder 8x 1MBx4 chips in and add A9, creating so a 4MB W32i ISA card? The W32i GPU chip has a MAD9 pin.PhilC wrote: 20 Jun 2025 11:29 BTW, this looks an interesting project
@frank.lukas the cards that I've seen that do 4mb all have 8 chips but I guess it's possible by adding the appropriate address line. You'd need to read the datasheet
agranlund
Updated rvbios to claim _MCH cookie value 0x00070000 for Raven instead of having it as -1
(V4SA is using 0x00060000 so I took the next free one as far as I'm aware)
agranlund
Blasphemy? :lol:
A friend of mine lend me his Sam460 board so I thought I'd teach it the ways of the Atari.
Sadly, crosstos-purec runs a bit too slow for comfort on that little board so it's not really viable to use for cross compiling Atari/Raven code.
(and building the m68k-atari-mint-gcc cross compiler for this host is way out of my league :lol: )
