ST536 STE EDITION
dml
Re: ST536 STE EDITION
Post by dml »
A typical behaviour for an upgraded CPU boot sequence is something like this:
cold boot:
- detect installed RAM types
- test the installed RAM areas
- optionally shadow ROM to RAM
- install MMU pagetables making the RAM & shadowed ROM areas available with the correct cache flags etc.
- mess with the warm-reset vector so all this doesn't need repeated on a warm boot
- MAYBE perform a warm-reset so every 'real' journey to the desktop is exactly the same (i.e. always via a warm boot, even from a cold boot)
warm boot:
- find the FastRAM from state detected/stored somewhere on the cold boot
- put the MMU table registers back (already set up)
- coast onwards to the usual boot sequence
My current build of 206 now runs DOTT ! BUT I've "lost" TTram now. Likely one of the PAK patches turned it on. So need to fix that next.
The current problem is as was before, Hatari seems to ignore TTram with 206 for some reason. So hard to test the fixes without burning a ROM.. every..single.. time... :roll:
exxos wrote: Fri Jun 06, 2025 11:56 am My current build of 206 now runs DOTT ! BUT I've "lost" TTram now. Likely one of the PAK patches turned it on. So need to fix that next.
You don't have '24 bit addressing' turned on, do you? and Stock 2.06 doesn't do any TT-RAM detection, obviously.
I saw you mention grabbing the latest EmuTOS. 1.3 is still the current release although 1.4 is scheduled in the next week or two, I think.
Badwolf wrote: Fri Jun 06, 2025 12:06 pm You don't have '24 bit addressing' turned on, do you? and Stock 2.06 doesn't do any TT-RAM detection, obviously.
It seems Hatari turns it on automatically :roll:
Thanks, thought it had moved on a bit since I last did a ROM.
GOT IT!!
*only* 58 PAK patches in the startup file :roll: I went though them one by one.. recompiled.. retested.. and with these enabled with my TP_666 patch, DOTT resets! So the fault starts within this routine somewhere..
Ironically someone put "PAK WHY" in there already, but WHY indeed !
So next I need to go back to my original 206 build and disable that code and see if things still work.. hopefully that will be the only problem..
In the bloody mono check routine!
This is suspicious. Mono check getting triggered in EmuTOS -- an unrelated codebase. Mono check getting patched here for an 030 accelerator. Wherefore?
Badwolf wrote: Fri Jun 06, 2025 2:45 pm In the bloody mono check routine!
:lolbig:
:dizzy:
@Badwolf good spot though! My brain only registered "blah blah MFP blah blah" :lol:
I copied my original 206 back over and patched that one thing.. DOTT now runs! So 100% that bit of code caused the resetting issues with DOTT with my build of TOS.
For some reason that "patch" was done in the PAK patches :shrug:
Next to burn a ROM and see if I get TTram back now..
ROM burned, its not resetting, but the screen just remains black :roll:
Rebooted and now running.. still possible something is unstable on the booster though... but this is a HUGE step forward at least!
Grok explains :hide:
But as it mentions checking monodetect twice, maybe its trying to debounce the signal.. Maybe stems from previous attempts at fixing the mono detect issue which was replaced by the F-series chip on later motherboard revisions.. But even so, a debounce would make sense as a fix.
But still , It doesn't make much sense why the registers seems to get cleaned and ignored with PAK ?!
All this needs someone with more than 2 functioning brain cells to figure out.. :lol:
Analysis of 68k Atari ST TOS Monochrome Detection Snippet and TP_666 Reset Issue
The provided 68k Atari ST TOS code snippet is a routine for detecting a monochrome monitor by checking the MFP (Multi-Function Peripheral) chip's General Purpose I/O Port (GPIP) and the sound matrix control register (
sndmactl
). The issue arises when the
TP_666
flag is set to
, causing resets in a game or system. Below is an analysis of the code and why
TP_666 = 1
may lead to resets.
moncheck:
#if TP_666 /* PAK ?why? */
    move.b    #0,d0
#else
    move.b    ((sndmactl)+1).w,d0
#endif
    move.b    (MFP_GPIP).w,d1
    btst      #7,d1
    sne       d1
    move.b    (MFP_GPIP).w,d2
    btst      #7,d2
    sne       d2
    cmp.b     d1,d2
    bne.s     moncheck
    move.b    #0,d0
#else
    cmp.b     ((sndmactl)+1).w,d0
#endif
    bne.s     moncheck
    move.w    (a7)+,sr
    btst      #0,d0
    beq.s     nomoncheck
    not.b     d1
nomoncheck:
Code Breakdown
1. Initial Check and Conditional Code:
   #if TP_666
       move.b    #0,d0
   #else
   #endif
- When
TP_666 = 1
d0
is set to
- Otherwise, it reads the second byte of
sndmactl
into
d0
, which may reflect monitor or sound chip settings.
2. Monochrome Detection Loop:
   btst      #7,d1
   sne       d1
   btst      #7,d2
   sne       d2
   cmp.b     d1,d2
   bne.s     moncheck
- Reads the MFP’s GPIP bit 7 (monochrome detect) into
d1
and
d2
. The
sne
instruction sets
0xFF
(monochrome) or
0x00
(color).
- Loops back to
moncheck
if readings are inconsistent, ensuring a stable signal.
3. Second Conditional Check:
   #if TP_666
       move.b    #0,d0
   #else
   #endif
   bne.s     moncheck
- If
TP_666 = 1
d0
is set to
, skipping the
sndmactl
comparison.
- Otherwise, it checks if
sndmactl+1
matches
d0
, looping back if not.
4. Final Steps:
   move.w    (a7)+,sr
   btst      #0,d0
   beq.s     nomoncheck
   not.b     d1
nomoncheck:
- Restores the status register (
sr
), indicating an interrupt or privileged mode.
- If bit 0 of
d0
is set, inverts
d1
(monitor type). If
TP_666 = 1
d0 = 0
, so
d1
is never inverted.
Why TP_666 = 1 Causes Resets
When
TP_666 = 1
, the code forces
d0 = 0
, bypassing
sndmactl
checks. This can cause issues:
1. Bypassing Hardware Checks:
- Skipping
sndmactl
checks may allow incorrect monitor detection, leading to incompatible video mode settings (e.g., color mode on a monochrome monitor), which can crash or reset the system.
2. Impact on d0 and Logic:
- With
d0 = 0
, the
btst #0,d0
check always skips inverting
d1
. If the game expects inversion for correct monitor detection, this could lead to wrong video mode initialization.
3. Potential Infinite Loop:
- The
bne.s moncheck
loop ensures stable GPIP readings. Bypassing
sndmactl
checks might allow premature exit with incorrect data, causing downstream issues.
4. Game-Specific Assumptions:
- The
TP_666
flag (noted as "PAK ?why?") seems like a debug hack. It may break game assumptions about monitor type, leading to crashes.
5. System Reset Triggers:
- Incorrect video mode settings or invalid hardware accesses (e.g., to the Shifter or sound chip) can trigger resets on the Atari ST, especially in interrupt contexts.
Debugging Suggestions
- Trace Video Initialization: Check how
d1
is used to set video modes. Look for conflicts with the Shifter chip.
- Monitor Hardware Accesses: Inspect code accessing video/sound registers post-routine.
- Test Monitors: Try with monochrome and color monitors, toggling
TP_666
- Check sndmactl: Verify its role in your ST model for monitor or sound settings.
- Patch TP_666: Set
TP_666 = 0
to restore normal checks.
b]Emulator Debugging[/b]: Use Hatari to step through code, monitoring
d0
d1
d2
, and video registers.
Conclusion
The
TP_666 = 1
setting likely causes resets by bypassing
sndmactl
checks, leading to incorrect monitor detection and video mode mismatches. This can crash the game or system. Debugging with an emulator or testing monitor setups can help. If you have more code (e.g., video initialization), I can dig deeper!
