Raven060 (luciodra build).
Re: Raven060 (luciodra build).
Interesting solution @luciodra , mine pings but still no luck with UIP. I have an old NE2000 card that only has BNC and AUI, so have purchased an AUI to RJ45 transceiver and will see if that works.
Once I've got that to work I hope to be able to slowly get into the whole ISA programming thing in the hope we have more card choice in the future.
luciodra
Post by luciodra »
PhilC wrote: 18 May 2025 18:45 Interesting solution @luciodra , mine pings but still no luck with UIP. I have an old NE2000 card that only has BNC and AUI, so have purchased an AUI to RJ45 transceiver and will see if that works.
Your card must have the RTL8019 chip to have any chance of working.
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
luciodra wrote: 18 May 2025 19:28
That's the controller for my current card, it's set to 300h and IRQ10. On my Mac, doing a port scan I can see port 21 is open but I don't get any webpage or anything.
agranlund
Post by agranlund »
PhilC wrote: 18 May 2025 20:17 That's the controller for my current card, it's set to 300h and IRQ10. On my Mac, doing a port scan I can see port 21 is open but I don't get any webpage or anything.
There's no webserver running in this version, just the FTP server on port 21.
You should be able to do an anonymous ftp connect using an ftp client of your choice.
I think you might need to do passive mode but I'm not 100% sure.
@agranlund ah ok, that explains it. I'll go download FileZilla and get it working with that or something similar.
luciodra
Post by luciodra »
Finally the network card gives some signals...
ET4000AX 1Mb T0
PicoGUS 2.0
Great that you got it working and with an interesting solution as well
:cheer: :cheer: :cheer:
kodak80
Post by kodak80 »
Just to add to the information. My network card is 8 bit ISA.
luciodra
Post by luciodra »
kodak80 wrote: 19 May 2025 08:30 Just to add to the information. My network card is 8 bit ISA.
And in fact I was very interested in your card, and that's where I got my inspiration from. :D
ET4000AX 1Mb T0
PicoGUS 2.0
kodak80
Post by kodak80 »
luciodra wrote: 19 May 2025 09:00
:dualthumbup:
Also, the EtherNEC ISA Network adapter is only 8 bit as well. This is where I was using my ISA network card originally.
Return to “RAVEN 060 - USER BUILDS”
