I just get garbage on a black screen... I assume it's some bug in the game itself. It's all beyond my skills to diagnose software issues like that. So will just have to be classed as "no fix/wont fix".
ST536 STE EDITION
Re: ST536 STE EDITION
coonsgm
Are you able to autoboot from IDE though?
EMUTOS yes.. TOS won't if they are byteswapped (pc compatible). EMUTOS will boot BS IDE, But TOS won't.
The workaround is to boot HDdriver from floppy with TOS. Or loose the pc compatibility so auto boot works.
coonsgm
Under modded TOS 2.06: Non-Byte swapped with HDDriver installed not recognizing the IDE drive or autobooting from it using either Current3 or Current4.
I'm going to see if there were any other physical things changes (other than the small PCB patch installed a couple months ago) that I'm missing.
ACSI working perfectly under modded TOS 2.06.
Everything working just great under EmuTOS
coonsgm
My IDE buffers are HT245 and RAM buffers are KS245
Have you installed the driver from the main program to c?coonsgm wrote: 10 May 2025 16:44 Under modded TOS 2.06: Non-Byte swapped with HDDriver installed not recognizing the IDE drive or autobooting from it using either Current3 or Current4.
I'm not at home to check... Maybe @PhilC can say whats supposed to be there. TTram would fail if the wrong buffers are there. If you not changed them then it's likely they are wrong...
They sound correct to meant near my STe at the moment, so going from memory. If you are able to access the IDE but not boot from it then in sounds like the buffers are working but you don't have the driver installed on the C drive. I've been using mine with the BBAN HDD, so not got round to testing IDE much but it did work fine in Emutos for all of the five minutes I used it.
coonsgm
Kept to like 256MB partitions and made sure TOS only selected and byteswapped isn't ticked ?
Otherwise it have to wait for me to try when I get back home tomorrow night.
