ST536 STE EDITION
Re: ST536 STE EDITION
coonsgm wrote: 10 May 2025 00:50 Looks like I soldered the PLD just ever so slightly misaligned
Got to remove and resolder the .... oh the joy!
Yeah that happened to me as well...
Is it even a proper QFP chip if it's not been soldered, desoldered and soldered again?
I remember so many cycles back in the early days of the DFB1 project!
I'll still have nightmares about making a big play of the pin one marking on one of my videos then proceeding to solder it 180 degrees out. On camera.
FFS. :lol:
Badwolf wrote: 10 May 2025 00:59 I'll still have nightmares about making a big play of the pin one marking on one of my videos then proceeding to solder it 180 degrees out. On camera.
:lol: Those chips which have multiple dots annoy me ! Is it the big dot or the small dot or the corner with no dot :roll:
It's not the AB code causing it...
I disabled TTram and STOS loads fine in 206.
I could guess STOS doesn't like TTram...
BUT, why would STOS work fine in EMUTOS..
BUT2: STOS loads fine from floppy.
BUT3: STOS loads fine from Ultrasatan
So if I boot HD11 from floppy (not ultrasatan) STOS loads fine from IDE. So there must be some odd conflict going on between Ultrasatan and the IDE.. but as some drives are "missing" maybe because C: is there on both drives etc, something goes nuts.
BUT EMUTOS doesn't seem to care..
Reminds me when I tried freeminit a while ago, that went batshitcrazy. I suspected as I was booting from Ultrasatan and loading files from IDE.. Never looking into that more anyway.
So I guess do not use 2 hardrives at the same time else something goes nuts..
coonsgm
Post by coonsgm »
Resoldering done and successful. Flashed current4.jed and am now prepping a CF card for HDDriver installation (starting with a fresh install of everything).
coonsgm wrote: 10 May 2025 14:31 Resoldering done and successful. Flashed current4.jed and am now prepping a CF card for HDDriver installation (starting with a fresh install of everything).
:bravo: :2k2:
Nice wall picture ;)
coonsgm
Post by coonsgm »
exxos wrote: 10 May 2025 14:54
:bravo: :2k2:
Thank you!
Under Modded TOS 2.06
Current4.jed firmware
So far autoboot from ACSI (Ultrasatan with HDDriver) is a go. STDOTT runs. No IDE autoboot, BUT when autobooting from ACSI and the IDE drive is connected, the IDE is recognized and fully functional.
coonsgm
Post by coonsgm »
Spoke too soon. STDOTT does NOT boot under TOS 2.06. It was EmuTOS testing that worked.
I would only use ide as I've mentioned problems with both connected. I've only tried DOTT with EMUTOS. Not sure it even works in TOS .
exxos wrote: 10 May 2025 15:25 I would only use ide as I've mentioned problems with both connected. I've only tried DOTT with EMUTOS. Not sure it even works in TOS .
It didn't work for me in TOS.
Users browsing this forum: ClaudeBot, facebookexternalhit and 29 guests
