Ok, so when I got my CF card the XT CF mini stopped working...
:headbang:
Before inserting the CF card, I switched the TANDY on but the nice BIOS boot screen I had posted previously has disappeared.
The Tandy simply boots like it would not have any CF IDE adapter installed in.
I launched XTIDECFG and could read the content of the EEPROM but when I wanted to re-flash it, there was an error.
There was no problem when I flashed it again with my EPROM programmer though.
:chairsmack:
New (and last ?) inbound
Re: New (and last ?) inbound
Interesting, I had a similar problem with my XT-ide. Sometimes I can write the ROM in situ, other times it fails. I sometimes get a ROM checksum error and it just boots to floppy.HigashiJun wrote: 10 Apr 2025 12:13 Ok, so when I got my CF card the XT CF mini stopped working...
:headbang:
:chairsmack:
Flashing in the TL866 tends to fix it. As yet I haven't been able to make any CF cards with mine.
@rubber_jonnie
Quite weird...
I will have to check further tomorrow.
I am really fed up today.
:twisted:
Quite weird...
:twisted:
Hope you feel better, definitely weird and something I need to get back to as well.HigashiJun wrote: 10 Apr 2025 13:22 @rubber_jonnie
Quite weird...
:twisted:
Still issues with the XT CF mini.
I can know flash the chip again while fitted in the Tandy, but it's not always recognised when I launch XTIDECFG.
I guess the 28C64 EEPROM is somehow faulty...
Ordered a 27C64 EPROM and now have to wait 2 or 3 days.
:crossed1:
:crossed1:
I may try the same, I think I may have some 27C64s in my parts drawer.HigashiJun wrote: 12 Apr 2025 02:59 Still issues with the XT CF mini.
:crossed1:
I am wondering if I can run the config software on my Book 8088 and dump the XT-IDE ROM from that and burn it to my card/ROM and see if that works.
Ultimately I'll be using the PicoMem mostly but I'd really like to get the XT-IDE working.
Unfortunately, I have all sorts of EPROMs in my parts box but not a 27C64...rubber_jonnie wrote: 12 Apr 2025 09:59 I may try the same, I think I may have some 27C64s in my parts drawer.
I ran the config software on DOSBOX on my Mac, and there was no issues at all. Should be good on your Book 8088 too.
I just found my 27C64's, but they need UV erasing first. I'm just in the middle of populating my 610 expansion board, so I will probably look at it when I've finished with that. I'm mostly just smoke testing that right now, so far it all looks to be as it should.HigashiJun wrote: 12 Apr 2025 10:24Unfortunately, I have all sorts of EPROMs in my parts box but not a 27C64...rubber_jonnie wrote: 12 Apr 2025 09:59 I may try the same, I think I may have some 27C64s in my parts drawer.
Should be easy to get the config off the Book 8088 as it has a USB drive :) I'll test on my PPC512. I'll let you know how I get on.
Thanks !rubber_jonnie wrote: 12 Apr 2025 11:27 Should be easy to get the config off the Book 8088 as it has a USB drive :) I'll test on my PPC512. I'll let you know how I get on.
Hmmm.
It seems you can't dump the ROM from XT-IDE with the config tool, so getting one out of my Book 8088 isn't going to be possible, however I can probably use the tool to copy the config from side by side, so that's up next.
Having done the side by side changes, the XT-IDE works to the extent that the PPC will now boot and not freeze. However the CF card was not seen.
One of the main things I changed was the drive type to BIU 8 which is one of the XTCF options and I also disabled the slave drive detection.
I guess it's progress, but still not there.
Users browsing this forum: ClaudeBot, mikro and 13 guests
