A little help please - Flat Flex Cables
Hi all.
I'm trying to get a 10 or 20 cm FFC and the pitch is as follows:
To me the contacts look like 1mm with a pitch of somewhere between 1 and 1.5mm. If anybody can advise on the pitch I'd be grateful as I may be missing something and every one I've ordered has had the wrong contact size and pitch despite what the details said.
Re: A little help please - Flat Flex Cables
I would guess 1,27mm which is half of 2,54mm and both are standard. Otherwise I would use a caliper to measure.
EDIT: But searching seems to suggest that normal FFC pitch is 1,25mm.
ThanksDoG wrote: Wed Apr 02, 2025 3:07 pm I would guess 1,27mm which is half of 2,54mm and both are standard. Otherwise I would use a caliper to measure.
Wouldn't surprise me tbh. It's a laptop keyboard ribbon and very annoyingly dead.
Looks like 1.25mm pitch to me. I think @alexh has it right.
Thanks, I think that's correct in terms of pitch, but 8" is way too long and my other concern is the digi-key pricing for shipping, which in this case is £12!!!alexh wrote: Thu Apr 03, 2025 10:11 am Something like this ?
https://www.digikey.co.uk/en/products/d ... 69/4427997
Food for thought though, thanks.
BTW I broke out the calipers and it is 1.25mm pitch with 1mm contacts.
I agree. Off on a cable hunt.Badwolf wrote: Thu Apr 03, 2025 10:32 am Looks like 1.25mm pitch to me. I think @alexh has it right.
OK, I found some possible candidates at AliExpress with the correct pitch and pin count, so fingers crossed!
