Does @rubber_jonnie have a Z88?
I'm pretty sure he has the NC100 & NC200...
New arrival :)
Re: New arrival :)
I don't have a Z88 (I nearly did but that's another story) but I do have an Epson HX-20.JezC wrote: 27 Mar 2025 10:39 Does @rubber_jonnie have a Z88?
mgi
Re: New arrival :)
Those Epson early laptops are fantastic
Re: New arrival :)
@rubber_jonnie
BTW, how is your repair going ?
Re: New arrival :)
It's not. I thought I had bad RAM and replaced one, but didn't help. I'm going to get back to it soon and need to break out the scope, but I do wonder if it's a power issue.
Re: New arrival :)
So it's more complex than expected...rubber_jonnie wrote: 27 Mar 2025 12:08 It's not. I thought I had bad RAM and replaced one, but didn't help. I'm going to get back to it soon and need to break out the scope, but I do wonder if it's a power issue.
Re: New arrival :)
Very much so. It's actually a dual CPU machine and runs off battery, with power only for charging the battery. Basically if you remove the battery you can't run it off the charger.HigashiJun wrote: 27 Mar 2025 12:20So it's more complex than expected...rubber_jonnie wrote: 27 Mar 2025 12:08 It's not. I thought I had bad RAM and replaced one, but didn't help. I'm going to get back to it soon and need to break out the scope, but I do wonder if it's a power issue.
Re: New arrival :)
Yeah, that's what I read when I was looking for some information about this machine.rubber_jonnie wrote: 27 Mar 2025 12:31 Very much so. It's actually a dual CPU machine and runs off battery, with power only for charging the battery. Basically if you remove the battery you can't run it off the charger.
Re: New arrival :)
Whats annoying is it worked fine, then one day just stopped :(HigashiJun wrote: 27 Mar 2025 22:29Yeah, that's what I read when I was looking for some information about this machine.rubber_jonnie wrote: 27 Mar 2025 12:31 Very much so. It's actually a dual CPU machine and runs off battery, with power only for charging the battery. Basically if you remove the battery you can't run it off the charger.
Re: New arrival :)
Yeah, the kind of thing I hate...rubber_jonnie wrote: 27 Mar 2025 23:52 Whats annoying is it worked fine, then one day just stopped :(
Users browsing this forum: ClaudeBot, semrush [bot] and 3 guests
