Hi Jez, yes it is the BBAN SD adaptor. I'll probably make some kind of case or bracket for it.JezC wrote: Wed Mar 05, 2025 6:34 pm
Great progress with that @PhilC - is that the BBAN SD HDD adapter connected in there as well? Nice...
I've got one as well...just not sure which system it will end up as a permanent feature in (but one of my Megas is attractive because I cold lose the external supply)
@JezC yes you'll just need to make up an adaptor to go in the internal Mega ASCI port and pick up a supply from somewhere. Not worked that out yet but it won't be that hard to do. Then dig out Fusion 360 to make that bracket. I'll see if I can get it to fit in the expansion port hole.
Given the size of my retro to-do list (and the ongoing lack of time) I'm sure you will get there before me!PhilC wrote: Wed Mar 05, 2025 7:19 pm @JezC yes you'll just need to make up an adaptor to go in the internal Mega ASCI port and pick up a supply from somewhere. Not worked that out yet but it won't be that hard to do. Then dig out Fusion 360 to make that bracket. I'll see if I can get it to fit in the expansion port hole.
I'll happily be a second tester for anything you can create though!
I'm going to try and replace the battery on an FMC II cart tonight...as that's about as much as I expect to fit in to tonight's hobby time slot
Today you join me for this momentous occasion. For the first time in 5 years the Mega ST is about to have its case put back on.
Of course I'm not going to screw it on, it's a Mega FFS. It'll go wrong in about an hour.
PhilC wrote: Tue Mar 11, 2025 2:27 pm Today you join me for this momentous occasion. For the first time in 5 years the Mega ST is about to have its case put back on.
In between doing a few repairs, upgrades etc, I've got myself a little side project.
On the left is a working Rosco_m68k 68010 SBC that's up and running and on the right, it's bigger brother, a 68030 SBC. This one is waiting for a few bits abd pieces and should be running by the end of next week hopefully.
They both communicate over FTDI or RS232 but have the option of having a video card, which I will look at getting once I've got the 030 one working.
Nice @PhilC - I've seen those and been tempted myself (but so far, moments of sanity have reminded me how many other retro projects I have on the go that need finishing first).
