Atari Mega ST 1 Rev 1 no boot
- HigashiJun
Re: Atari Mega ST 1 Rev 1 no boot
May sound stupid, but do you have the correct cable ?
Is your cable a null modem cable? It needs to be.Dwh18 wrote: Fri Mar 07, 2025 12:20 pm Yes, all reverted ... but no onscreen duplicated on serial for sure
Bought it as a null modem.... might try with another onerubber_jonnie wrote: Fri Mar 07, 2025 1:05 pmIs your cable a null modem cable? It needs to be.Dwh18 wrote: Fri Mar 07, 2025 12:20 pm Yes, all reverted ... but no onscreen duplicated on serial for sure
Can I suggest you get some photos of the areas you've repaired when removing the RAM expansion and also a video of what you see during the boot on your terminal.
- olivier.jan
If you have a little serial to usb adapter (like ftdi232), you can connect RX and TX to pin 8 and 9 of the MFP (and GND anywhere on the motherboard’s ground), it will work directly at 9600 bauds.
Retro stuff
That's a great tip actually and helped me fix something totally unrelated and non Atariolivier.jan wrote: Fri Mar 07, 2025 6:43 pm If you have a little serial to usb adapter (like ftdi232), you can connect RX and TX to pin 8 and 9 of the MFP (and GND anywhere on the motherboard’s ground), it will work directly at 9600 bauds.
Ordered this oneolivier.jan wrote: Fri Mar 07, 2025 6:43 pm If you have a little serial to usb adapter (like ftdi232), you can connect RX and TX to pin 8 and 9 of the MFP (and GND anywhere on the motherboard’s ground), it will work directly at 9600 bauds.
Did some more digging and noticed u35 and u32 are different than U36 and U33. Is this supposed to be like this?
Are they the 74LS244 & 74LS373 chips? If so you should have two of each.Dwh18 wrote: Fri Mar 07, 2025 10:08 pm Did some more digging and noticed u35 and u32 are different than U36 and U33. Is this supposed to be like this?
- olivier.jan
The adapter you have should work, what I was mentioning are the little usb to serial (not RS232) like this: https://amzn.eu/d/dCjUFvn.
Anyway, if you want to check : Pin 8 of the MFP is TX while pin 9 is RX. So, if the diag cart is sending dat, you should see activity on pin 8 when you start the ST. You can test also the other direction: if you type data in your serial terminal it should generate activity on pin 9 of the MFP.
If you have an oscilloscope, checking will be pretty easy. With a multimeter, set on DC, you should see some voltage variations when there is activity.
Retro stuff
