Just with the diag cart.Dwh18 wrote: 28 Feb 2025 09:32Quick question.... serial output only works with Diag cart on right? or a regular boot should show some output?rubber_jonnie wrote: 27 Feb 2025 11:41
Definitely looking like a RAM issue. I'd definitely recommend using a serial cable, it will tell you an awful lot about the RAM during boot.
One thing I would add here is that the Mega ST mainboards are pretty fragile, so handle with care, I had one board where I plugged an IDE adapter into the MegaBus connector and it popped 2 vias and broke it.
Atari Mega ST 1 Rev 1 no boot
Re: Atari Mega ST 1 Rev 1 no boot
Dwh18
Hi
Not great output... get some artifacts in some tests but nothing special....One symptom I notice with the diag cart is that main menu takes ages to load
Is everything correctly set ?
Dwh18
I'm using 9600, N,1, and tried several control types ... HW, None, XonXoff
Any clue why Diag menu loads sooo slowwwww?
@Dwh18
I use Putty with an USB to RS232 cable, with the following settings:
Baud rate to 9600 , 8 data bits, no parity, 1 stop bit and no flow control.
Dwh18
With an adapter to convert DB9 to DB25?HigashiJun wrote: 07 Mar 2025 11:09 @Dwh18
Lots of errors?
It looks like you're getting a full character set dump (in ascending order) on your terminal so something's happening.
(BTW, a floating [or toggling] HALT or BR line could produce slow motion output)
No, there is no adapter.
The USB plugs directly into my USB port and the DB25 into the ATARI.
These settings are indeed correct.HigashiJun wrote: 07 Mar 2025 11:09 @Dwh18
You should see data on screen as the machine boots and you will eventually get a menu over the terminal that shows the same thing as on the computer screen.
Did you revert the RAM upgrade fully as yet?
Dwh18
Yes, all reverted ... but no onscreen duplicated on serial for sure
Users browsing this forum: ClaudeBot, semrush [bot] and 3 guests
