:)PhilC wrote: 21 Feb 2025 13:12Oh! now you've gone and done it. :hide:rubber_jonnie wrote: 21 Feb 2025 13:08 I'll go down this particular rabbit hole another day though as I want to bask in my success from this morning for a bit :)
A5000 - diving in at the deep end!
Re: A5000 - diving in at the deep end!
Great, thanks I'll have a look there and report back :)HigashiJun wrote: 21 Feb 2025 13:30 Maybe it's worth checking here:
https://acorn.huininga.nl/pub/mirrors/f ... ww/ArcWeb/
Hmm, Arcweb is going to require some more work. No change so far so I'd better read the instructions and see what I'm missing.
I suspect what fixes Arcweb will also fix Webster as both are complaining about there being 'no application loaded to handle this URL'
@rubber_jonnie
I will check my settings tomorrow if time permits and let you know.
Thank you.HigashiJun wrote: 22 Feb 2025 10:32 @rubber_jonnie
@rubber_jonnie
Sorry for the delay...
Had time to check my !Arcweb today, and now I remember that the only thing it was complaining about was the version of File Manager.
Once the right version was installed, it started to run:
Did you have a look in the readme files ?
So the filter manager version issue:HigashiJun wrote: 28 Feb 2025 03:57 @rubber_jonnie
I get round that by running !PrintWeb first and you end up with both icons in the task bar if you run Arcweb afterwards:
If you then close Arcweb, both Icons disappear and you can just run Arcweb:
And you can get the local files:
However this time I tried to connect to my local web server running IIS:
So I don't know what I did different to last time but it can load web pages from web servers using HTTP. It probably won't like HTTPS but that's not entirely unexpected.
@rubber_jonnie
Copy the attached FilterManager (unzip it on your Mac/PC desktop) into your PreDesk folder in !Uniboot and you should be able to run !Arcweb without launching !PrintWeb.
Thanks I'll give it a go.HigashiJun wrote: 28 Feb 2025 10:37 @rubber_jonnie
Users browsing this forum: ClaudeBot, DuckAssistBot, Majestic-12 [Bot] and 11 guests
