A5000 - diving in at the deep end!
Re: A5000 - diving in at the deep end!
HigashiJun wrote: 17 Feb 2025 21:48:bravo:
Would still be good to get FTPc going though.
Post by HigashiJun »
rubber_jonnie wrote: 17 Feb 2025 22:09 Would still be good to get FTPc going though.
Will check later today on my A3000.
HigashiJun wrote: 18 Feb 2025 02:55
Thanks 👍
@rubber_jonnie
Ok, just checked my NIC settings:
AUN and ACCES are in ROM, but they are not enabled in the Network Configuration panel:
And here are the other Internet settings:
Don't know if that helps though...
Anyway, let me know even if you have an ounce of any kind of progress.
HigashiJun wrote: 18 Feb 2025 08:22 @rubber_jonnie
Thanks for those, appreciate you taking the time.
Aside from the differences in IP address I'm set up the same, so I don't know what's going on with FTPc. Possibly the only other difference is that I use a HOSTS file for some local addressing, otherwise I'm using the same external DNS addresses as you too.
I'm just taking a full backup of the machine over to an NFS share using Sunfish. That will give me 2 complete backups of the boot drive locally, one on SCSI the other on IDE, and then a full backup of everything on my server, so that should give me plenty of room for recovery if I need to.
@rubber_jonnie
Can you try with the here attached FTPc ?
FTPc.zip
HigashiJun wrote: 18 Feb 2025 09:43 @rubber_jonnie
FTPc.zip
I'll give it a go, thanks.
My file backup is still going, it may be a while...
FTPc.zip
Same happened as with my copy, it tried to connect using FTPS not FTP. No joy.
FTPc.zip
BTW I downloaded the latest version, 1.56 and it doesn't crash with AcornSSL installed from the ROOL hard disk image. I class that as progress, however looking at the manual it seems there should be options to pick from the FTPc menu, but security for example has nothing in the list and according to the manual it should have several options to pick from.
So I need to have a closer look as to why that is, perhaps delete the existing config files and start again.
rubber_jonnie wrote: 18 Feb 2025 21:55 BTW I downloaded the latest version, 1.56 and it doesn't crash with AcornSSL installed from the ROOL hard disk image. I class that as progress, however looking at the manual it seems there should be options to pick from the FTPc menu, but security for example has nothing in the list and according to the manual it should have several options to pick from.
Yes, I have these options available in my settings.
Users browsing this forum: ClaudeBot, Google [Bot], Steve, xyzzy76 and 44 guests
