I wanted to install a TOS switch in my ST the other day. But I didn't want to drill a hole in the case, I wanted it to stay pristine as much as possible.
Since I already had a Gotek drive installed with a 3D printed bracket (which again, doesn't require case modifcation), I figured I could stick the switch in the bracket panel.
I would advice anyone who's thinking of getting a Gotek (or if you have one and didn't mill your case) to get hold of a 3D printed bracket: https://www.thingiverse.com/thing:2664753
I wouldn't mind printing a few of them and mail them for postage costs.
Anyway, nice solution, eh?
Leaving your computer case pristine - switch installation trick
Re: Leaving your computer case pristine - switch installation trick
Looks lovely!
One of my STEs has a TOS switcher installed (the previous owner drilled a hole in the case...D'Oh!) but the original floppy works fine in that one...but at the weekend I found that I have a 1040 STFM with a non-functional Epson 380 drive (which works fine with a Gotek though)...
I'm trying to find a semi-logical argument which means that I can get a 3d printer without being either killed/fed to the dog & cats/divorced as a result.
By all means, do it. I've got a 283 euro printer and I've had so much fun using it, it's been worth every penny. You might want to tell your partner you'll be able to fix things around the house with it, print broken cups and cutlery etc.JezC wrote: Mon Oct 29, 2018 11:02 pm I'm trying to find a semi-logical argument which means that I can get a 3d printer without being either killed/fed to the dog & cats/divorced as a result.![]()
Seriously, I fixed a few lost knobs, broken buttons etc. on various devices. Very satisfying, especially if you're interested in doing 3D designs (drawing existing stuff for repairs) although there's a lot to find online (thingiverse.com etc.)
I think i will have to earn lots of brownie points before I get away with thatsandord wrote: Mon Oct 29, 2018 11:09 pmBy all means, do it. I've got a 283 euro printer and I've had so much fun using it, it's been worth every penny. You might want to tell your partner you'll be able to fix things around the house with it, print broken cups and cutlery etc.JezC wrote: Mon Oct 29, 2018 11:02 pm I'm trying to find a semi-logical argument which means that I can get a 3d printer without being either killed/fed to the dog & cats/divorced as a result.![]()
What a neat idea, wasnt relishing the idea of drilling extra holes in the case when i get my Dual TOS board
I just got a 3d printer for £90, and whilst its far from perfect, it certainly is a starting point, and good enough to print off that Gotek mount, of which I've now done two.JezC wrote: Mon Oct 29, 2018 11:02 pm
Birthday was the charm for me, though I need to find a way to quieten it down as the printing is a bit noisy, even upstairs in my man cave.
Hmm, that's a bit more affordable. Almost an option for a Christmas present...rubber_jonnie wrote: Tue Oct 30, 2018 8:57 amI just got a 3d printer for £90, and whilst its far from perfect, it certainly is a starting point, and good enough to print off that Gotek mount, of which I've now done two.JezC wrote: Mon Oct 29, 2018 11:02 pm
Of course for £90 it isn't going to be 100% wonderful, but you have to start somewhere. I've already started looking for upgrade options such as belt tensioners and braces.JezC wrote: Tue Oct 30, 2018 10:05 am
Hmm, that's a bit more affordable. Almost an option for a Christmas present...![]()
Took me about 6 hours to assemble (Yes you read that right, 6 hours), then I spent another 2 hours setting up the bed and auto leveling, but it's good fun, and worth the effort.
What's great is that once you have it working in a basic format, you can print enhancements for it! If you want to build your own stuff, you'll need a CAD program. I'm trying out Fusion 3d atm, it seems really easy to use, and you can get a free version for personal/hobbyist use.
