The latest member of the family
Re: The latest member of the family
Apparently the biggest problem with the Commodore PSUs is actually the 5V regulation circuit which can fail, sending higher voltages down the line. THere's probably just a regulator you can swap out though.
The benefit of RGB2HDMI over solutions such as RetroTink or OSSC is that the signal never leaves the digital domain, no DAC+ADC. It is digital RGB to digital HDMI. The best picture quality possible.
Yeah, I also thought it might be worth doing whilst it's open, I'll take a look.stephen_usher wrote: 29 Jan 2025 13:36 Apparently the biggest problem with the Commodore PSUs is actually the 5V regulation circuit which can fail, sending higher voltages down the line. THere's probably just a regulator you can swap out though.
It feels like it isn't starting TBH as the power light is flashing on and off.
Yeah, very true.alexh wrote: 29 Jan 2025 13:38 The benefit of RGB2HDMI over solutions such as RetroTink or OSSC is that the signal never leaves the digital domain, no DAC+ADC. It is digital RGB to digital HDMI. The best picture quality possible.
Higgy
I've heard about this on C64, but not on Amiga PSUs.stephen_usher wrote: 29 Jan 2025 13:36 Apparently the biggest problem with the Commodore PSUs is actually the 5V regulation circuit which can fail, sending higher voltages down the line. THere's probably just a regulator you can swap out though.
My C64 PSU looks a right bodge, I cut the 5v line and glued to the top a Sony PSP 5V PSU :lol:
Well, the A1200 PSU is giving out a good 5v, 12v & -12v after replacing some of the caps (47uF's are on order), so that's something.Higgy wrote: 29 Jan 2025 16:26I've heard about this on C64, but not on Amiga PSUs.stephen_usher wrote: 29 Jan 2025 13:36 Apparently the biggest problem with the Commodore PSUs is actually the 5V regulation circuit which can fail, sending higher voltages down the line. THere's probably just a regulator you can swap out though.
Going to also check the accelerator card for shorted SMD caps just in case.
OK, so it's been a bit more about the A1200 than the A500 of late, but it seems that the PSU alone wasn't part of the issue.
I've recapped the accelerator board and I've checked the SMD caps for shorts and it's all good there. I also gave the edge connector a good scoosh with contact cleaner (again) and things seem to have stabilised, though I am using the A500 PSU with the A1200.
Once the new caps come I'll try again with the A1200 PSU.
I'm just hoping you have a lot less hassle with the A500...
:crossed1:
:crossed1:
No worries, but please give me some time.rubber_jonnie wrote: 29 Jan 2025 13:11 As for the GW I'm just finding it won't write ADF files at all. @HigashiJun if you have any pointers I'd be grateful.
I have to take out my GW from the closet, find my 3.5" floppies and take a screenshot of the settings.
Oh, and BTW, I have the following PSU for my AMIGA 1200:
https://amigastore.eu/en/683-a-power-hq ... 01200.html
It works really great even with a TF1260 fitted.
