330 disable function bug
68030 + SDRAM + IDE
Mister_Grave
Re: 330 disable function bug
Post by Mister_Grave »
I think I'm going to take the opportunity to order a Tf360. How should I go about it?
supaduper
Post by supaduper »
Either me or Alenppc can sort you out with a TF360
Mister_Grave
perfect, but you live in England right? I'm going to pay a lot of money to travel to Europe!
Mister_Grave
i ve tried to sent you a pm, but i think it doesn't work
Mister_Grave
I received my Xilinx programmer, and I was able to update the firmware. The good news is that the card works again (yes!). On the other hand, the switch still does not work!
Mister_Grave
Is it possible that a component has failed?
supaduper
Post by supaduper »
We don`t know send it back to the seller and explain what happend
Also if you have multimeter check that there is around 3v on the each of the two disable pins
Mister_Grave
Just tried, Voltage are good for both
Mister_Grave
I did a flash again just in case... No difference, with jumpers on or off or even without jumpers at all. The card remains activated.
Ok help me out here. If you have some dupoint wires try and short the shown pin here on the disable header to GND or VCC33.
Remember the enable/disable only takes effect at reset or power on. if you change it with the machine running it wont do a thing.
I wonder if your reset line has an issue and thats whats causing this.
Return to “TF330”
