Hxc vs flashfloppy
PeteW
Hxc vs flashfloppy
Post by PeteW »
Up to now I've been using a gotek with flashfloppy. I've been really pleased with the results but there are times where it can't cope with some files (stx, msa). From what I've read, Hxc firmware can address some of these issues (for a small licensing fee)
Anyone here had experience of the hxc firmware? I'll probably buy another gotek drive to try it just so I don't mess up my current working setup
kodak80
Re: Hxc vs flashfloppy
Post by kodak80 »
I think what you need to look for is the .HFE disk image format. Both FlashFloppy and HxC can use this format for protected disk images. HFE version 3 now supports a large number of disk protection mechansims. Quite a few .STX disk images can be converted to .HFE format using the HxC Emulator manager software.
Neither the FlashFloppy or HxC firmware works with .STX format. .MSA is just a compressed image format and these can be converted to .ST easily to work with both FlashFloppy and HxC.
sandord
Post by sandord »
I have two Goteks, one with FlashFloppy and one with HxC.
I haven't noticed any difference in compatibility lately (FlashFloppy used to have problems with single sided disks but they fixed that a month or so ago).
The HxC image selection software (I can't remember its exact name right now) is showing two warnings at startup though if you run it with a non-hxc firmware. Nothing inhibiting but a little annoying. Even with FlashFloppy you'll want to be using this software because it is simply unsurpassed or even matched by anything else.
Regarding image format compatibility, HxC doesn't directly support compressed images such as MSA. It would simply require too much performance from the Gotek. What HxC provides instead is a utility to uncompress the image beforehand on your computer.
PeteW
Post by PeteW »
Thanks, so is the hfe conversion software part of the licensed software from hxc?
Sounds like it's the converter I need rather than updated firmware
sandord
Post by sandord »
PeteW wrote: 27 Oct 2018 10:01 Thanks, so is the hfe conversion software part of the licensed software from hxc?
I don't know but I'm using another (free) conversion utility that so supports batch conversion. It's in French though and I don't know it's name. I can look it up later but surely it won't be hard to find online.
kodak80
Post by kodak80 »
HxC Emulator manager is free.
https://hxc2001.com/download/floppy_dri ... r_soft.zip
This download contains the Windows and Mac versions. There is a batch conversion process in there as well.
I also have Goteks with both firmwares. Given the work Jean has done with the HFEv3 format, well worth supporting his firmware to keep the development going.
Converting is very easy using the HxC Software.
Just load the .st or .msa etc file and export it out as .hfe
PeteW
Post by PeteW »
Thanks all. I'll buy the firmware anyway to support the work the developer is doing, but for now it sounds like I only really need the manager software.
Will download it later and give it a try!
sandord
Post by sandord »
PeteW wrote: 27 Oct 2018 10:18 Thanks all. I'll buy the firmware anyway to support the work the developer is doing, but for now it sounds like I only really need the manager software.
Remember that once the HxC bootloader is flashed into your Gotek, you can easily switch between FlashFloppy and HxC because FF works fine with the HxC bootloader. The bootloader is tied to your HxC license so you'll want to leave that in or otherwise you'll have to buy a new license.
Interesting, I don't get any errors using the FlashFloppy firmware and HxC image management software (Autoboot.hfe), and the software nicely reports the version of FF I'm using on screen.
