Copy-Protected Disk (Once it dies, software gone)
General Discussion, STOS.
Cosmic Puppet
Post by Cosmic Puppet »
I recently purchased C-Lab Aura software. It's great, but there is no way to back up this 35 year old disk. Making a copy in fast copy doesn't work. Also copying the flux data and writing that back to a blank floppy doesn't work. How do I make a useable backup?
Oh and Happy New Year!
coonsgm
Re: Copy-Protected Disk (Once it dies, software gone)
Post by coonsgm »
To clarify copying the flux data means using a greaseweazle to create an HFE doesn't work?
Cosmic Puppet
coonsgm wrote: 05 Jan 2025 18:33 To clarify copying the flux data means using a greaseweazle to create an HFE doesn't work?
It created a file named "mydisk.scp" after copying the flux data, which I wrote straight back to a blank floppy disk. It copied all the files perfectly but the copy protection was still present stopping the program from running.
coonsgm
Post by coonsgm »
Dang, that's a puzzler. I've use flux data copying with my greaseweazle to copy some pretty tough copy protected original game disks like Dungeon Master. So far it's always worked for me (not saying I've tested all scenarios).
Cosmic Puppet
coonsgm wrote: 05 Jan 2025 19:21 Dang, that's a puzzler. I've use flux data copying with my greaseweazle to copy some pretty tough copy protected original game disks like Dungeon Master. So far it's always worked for me (not saying I've tested all scenarios).
Just tried an .scp file of it that I found on-line. Wrote it back to a floppy and it's still copy-protected, so...
coonsgm
Post by coonsgm »
Ah so you didn’t create the flux data yourself from your own disk. Got it!
Cosmic Puppet
coonsgm wrote: 05 Jan 2025 19:45 Ah so you didn’t create the flux data yourself from your own disk. Got it!
I did both. Did it with my own disk first. Then I tried the file from the internet in-case someone had sorted it. It means we have archived files that will never run because of the copy-protection.
czietz
Post by czietz »
Cosmic Puppet wrote: 05 Jan 2025 19:50 I did both. Did it with my own disk first. Then I tried the file from the internet in-case someone had sorted it. It means we have archived files that will never run because of the copy-protection.
I wonder if the .scp file from the Internet would run under an emulator...
EDIT: The .stx from here https://www.atarimania.com/utility-atar ... 23517.html works under Hatari:
EDIT2: And the .scp from there works under Steem:
Cosmic Puppet
czietz wrote: 05 Jan 2025 20:03
I'd forgotten about them lol Kinda stuffs real hardware though. About to try some files from another source...
Cosmic Puppet
Nice! I just tried another source from the net and it crashed in EmuTOS and Bombed in TOS 1.04
So it seems currently no way to back it up for original machines without it being cracked.
Return to “SOFTWARE”
Users browsing this forum: ClaudeBot, Qwantbot and 5 guests
