BTW if your network card has a BNC port on it, it's likely to be pretty old! :lol:
Hopefully you can pick up another NIC quite cheaply and see how that tests?
It may be, but why does the same result happen if I connect it to another computer (with a normal or cross cable)?viking272 wrote: 03 Jan 2025 09:42 Is it a 10mbps ethernet or does it connect at 100? Many routers don't support 10mbps.
Because your computers don't support 10mbps also?
Now I'm really curious what jumper 3 actually is but finding the manual is probably close to impossible :)luciodra wrote: 12 Jan 2025 16:00 I discovered that by moving jumper 3 from position 1-2 to 2-3 Emutos is solid as a rock and some artifacts that I had by moving the icons disappeared, at the expense of performance. Mint always gives me problems but I'm waiting for the 060 rev.6 for the conclusions...
This is a very similar board by the same make:agranlund wrote: 12 Jan 2025 21:13 Now I'm really curious what jumper 3 actually is but finding the manual is probably close to impossible :)
Users browsing this forum: ClaudeBot and 14 guests
