BOOKMARK THIS PAGE !
Raven060 (luciodra build).
luciodra
Re: Raven060 (luciodra build).
Raven 060 rev 6 96MHz
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
medmed
Arf...
Thanks for testing.
It seems there's more work to do to have a less fpu kernel than just -msoft-float.
It should need some asm tweak skills that I don't have.
Any way many thanks @luciodra
luciodra
luciodra
These are the results of this nice test, under Freemint, 060 96MHz and emulated fpu.
With the emulated fpu I was able to launch Doom, OperTyrijan but with a dramatic frame rateI...can't use the network card... on Emutos I can go it but the MAC gives it to me 00:00:00:00:00:00 (Always with emulated FPU).
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
Cool! Glad the fpu emu proved usedful.luciodra wrote: 19 Dec 2024 16:36 These are the results of this nice test, under Freemint, 060 96MHz and emulated fpu.
That old Doom binary is taking an FPU codepath on 68060 so it'll be incredibly slow with an emulated one.
And the old SDL it was built against has pretty slow NOVA graphics too and it doesn't support xbios input on clones.
I'll share my version when I get around to recompiling it, it takes the non-fpu codepath on LC.
But the code is in a bit of a state as I left it... I think I was working on audio support and then something more fun grabbed my attention...
luciodra
Have you ever tried to use the network card under Emutos with Sting?agranlund wrote: 19 Dec 2024 17:34Cool! Glad the fpu emu proved usedful.luciodra wrote: 19 Dec 2024 16:36 These are the results of this nice test, under Freemint, 060 96MHz and emulated fpu.
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
agranlund
luciodra
I've spent the last few days trying to get Emutos+Sting to work with the driver provided in Raven. In the end I got some results but I can't make them see the outside.
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
viking272
Can your router ping the .131 Raven ip address?
Or can other devices ping the .131 address?
Not sure if you have a ping tool (in Mint maybe?) to ping from the raven to your router?
Some routers have mac address filtering enabled.
Otherwise this post has some Sting trouble shooting like defining dns/router addresses: https://www.atari-forum.com/viewtopic.php?t=9169
luciodra
No. :cry:viking272 wrote: 22 Dec 2024 18:29 Can your router ping the .131 Raven ip address?
ET4000AX 1Mb T0
PicoGUS 2.0
ET4000AX 1Mb T0
PicoGUS 2.0
Users browsing this forum: CCBot and 6 guests
